200 x help please.
Hi Guys. I just picked up an 85 200x. It has a red painted swingarm( box section) It may be stock and just painted unless those came red. I am trying to tighten the chain. It doesn't seem to have the set up like the 250R or 350x. How do you tighten the chain on these? There are no bolts on the back of the swingarm near the carrier so it must adjust some other way I hope.
Also, the rear sprocket seems to be loose on the axle. It looks a clip of some sort holds it on. Is this commom? CVan I just add some small spacers to get rid of the play, or tighten it somehow, or is it just worn out? I have never had a 200x so thanks for any help guys.
own:
1986 250R- ported polished, carb mods, Esr atc-5 pipe and silencer
1986 250R- mild porting, carb mods (Clean!)
1985 350X- all stock (super clean!!)
1985 350x- desert project in the works
1986 250sx- Mostly stock
1985 200x- (pretty clean mostly stock)
1985 Yamaha tri zinger 60
