Haha, I have never used a manual...anything before. In fact, I thought that was the brake lever. Anyway, I have a couple questions;
1) Theres a button called PKE on the bike... whats that?
2) How do I safely use a clutch, haha?
I think that PKE is the parking brake. You push the button down, and pull the clutch to lock it in place. Play with it a bit, its pretty simple.
Best way to learn a clutch, is to get out and ride. A good way Ive tought people in the past;
Keep the engine RPM's solid as you engage the clutch. If the motor starts to die down, either give it more gas, or pull the clutch a little.
Get out and ride, you'll have it in no time!
1) atc-eric has the right idea
2) pull in the clutch shift into gear give it a little gas (not alot unless you want wheelie) and slowly release the clutch until you feel it engage, when it does the bike will move and your fine.
if you dont already know when shifting into a gear while moving (2nd, 3rd,4th ect....) let off the gas pull in clutch shift, little gas and relase clutch. once you get used to it youll be fine.
if you run into trouble clutch is your friend pull it in and your fine. my first manula was a pitbike, and i would either stall the bike or flip it untill i got the hang of it.
relase clutch too fast and the bike will stall if you dont give it gas.
give it too much gas and relase clutch too fast and youll be on your bum before you know what happened
have fun with it, i like manual better than semi or auto, and there are lots of fun things you can do with them when u get the hang of it
Current Project:1978 Pontiac Phoenix 355 v8
Past Bikes: 1999 Yamaha Big bear 350, 1981 Yamaha XS 400, 1996 Yamaha yz250 1984 Honda big red, 2004 Xtreme cr107, 1999 Yamaha bear tracker, 1999 Suzuki ds80 STOLEN, 2005 Kawasaki klx110, 1986 Honda trx200sx
Daily Driver: 1990 Buick Electra Park Avenue 3.8 v6
ok first thing is first, FIND NEUTRAL. its halfway between 1st and 2nd. second is when you start out pull the cluitch in, go to first, give it a litle throttle so your rpms are up and SLOWLY let the clutch out. Once you get moving and have the RPMs up let off the throttle, pull the clutch in, shift up, and release the clutch. Do not engage slowly at this point. And just get used to it. after a while you'll figure out that you only need the clutch for starting and stopping. On the tri-z i can find neutral while moving without the clutch![]()
When we taught my girlfriend she got it pretty quickly after I told he to let off the clutch the same amount as giving it gas. (kinda don't make sense lol) but after that she got it pretty quickly.
the hardest part is pulling out... After you get going it's just a matter of pulling in the lever before you shift then releasing it afterwards. When you slow down it's pretty much the same deal. downshifting until coming to a complete stop.
Its exactly like driving a stick shift truck or car, ever done that?
1978 ATC 90
2001 400EX
Not when you rev match.please explain this to me
BIKES CURRENTLY IN MY GARAGE
1990 XR80R
1983 CR60R
1986 250SX
1985 250R
Rev Match. Never heard it called that. We called it floating the engine. It's where you match RPMs with ground speed so that no load is on the engine. Unless I'm thinking way out in left.
hey, first... lean forward. let off the brake. let off the clutch, put on the gas. say bye bye.
one cylinder is not enough!!
Rev match:
When your engines RPM's match the next gear. Its when your high in the RPM's in 2nd gear, and you shift to third (without the clutch). You can feel the point where it smoothly kicks to the next gear.
Trial and error is the best way. Try not using the clutch through the middle gears, like I said you can feel the point where it dosent "CHUNK", instead it smoothly hits the next gear and you hit the gas.
Each bike is different, you have to get the feel for what you ride.
Wow, an actual term for it, revmatch. I've been doing it for years & never thought somebody'd rig a name up for it?
Baltimore---Charm City, or Harm City? Ask Pat.....
this isnt bad for the tranny at all? im very confused why wouldnt you want to use the clutch and if u can do this why would you use a clutch
