Thread: Need Some 200ES Timing Help Bad !!!
    neo19672000's Avatar
    neo19672000 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2006
    USMC N.C.
    229
    Can anyone please tell me in laymans terms how to set the timing on my 84, 200ES? Its my wifes and I believe she will hurt me badley when she finds out its not running anymore. Any Help will greatly appreciated. Thanks -Brock
    Update: Timing is fixed only to finally realize that I have a bent axel anybody got one?
    Mar 2007
    Howard Beach, New York, United States
    687
    if you look in dammnits signiture he has al the manuals, sounds like your havin the exact problem my es im sellin has
    Current Project:1978 Pontiac Phoenix 355 v8
    Past Bikes: 1999 Yamaha Big bear 350, 1981 Yamaha XS 400, 1996 Yamaha yz250 1984 Honda big red, 2004 Xtreme cr107, 1999 Yamaha bear tracker, 1999 Suzuki ds80 STOLEN, 2005 Kawasaki klx110, 1986 Honda trx200sx
    Daily Driver: 1990 Buick Electra Park Avenue 3.8 v6
    Aug 2006
    USMC N.C.
    229
    bump up for axle
    timex69 is offline Just Too Addicted Arm chair racerJust too addicted
    Sep 2003
    Saskatchewan
    485
    To set timing
    make sure your machine is on its compression stroke (there will be play in both rockers if it is on it, or if you put your finger over the spark plug hole and pull it over your finger will be blown off the hole.
    Next
    through the timing window on the left hand crank case align the 2 slots on the cover up with the line on the fly wheel right before the T. Then line the "O" on the cam sprocket up wth the groove, tounge, slot..whatever you want to call it on the top of the cam wall. I hope this helps, its almost easyer to get a freind who is good around motors to come over and help you. Mechanics over the internet can be tricky. Let me know how you get along.
    Alex
