Results 46 to 50 of 50
Thread: I dont get it?!
  1. #46
    Apr 2006
    PA
    1,464
    Well I just checked again, I couldnt really see outside when it was light. But now when its fully revved its black smoke. Running rich I guess. But yeah I was wondering about that, where would I get an adaptor for it? Im pretty sure its a 12 also.
    The slide is sliding the whole way up. I made sure of that, Last time I had it revving scarry high. I wish it had some kind of limited so I wouldnt blow it up when the throttle sticks WOT.
  2. #47
    Sep 2005
    Lipetsk, Russia
    2,824
    Sounds like your 200X needs a lot of TLC...
    Have you got a compression tester yet?
    I'm back in the USSR...
  3. #48
    Apr 2006
    PA
    1,464
    Yeah you could say that... Ive already put near $900 into it, bought it for 200. It was a great deal and was in exceptional shape for $200. But alot of little things needed replaced and fixed. If anything major is wrong with the engine its getting parted or sold. I cant keep fixing everything that breaks or wears out. So far i fixed or replaced: Tires, plastic, clutch, seat cover, forks, clutch lever, throttle, handle bars, exhaust, bearings (gone already, in a rad carrier), sprockets, chain, shock bushings, air filter, hubs, axle, a couple motor mounts, pegs, skid plate, intake boot, fork seals, front wheel bearings. And its nowhere near close to being pretty.
  4. #49
    Sep 2006
    S.E. LA
    700
    Did you check the compression yet?
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
  5. #50
    Feb 2006
    Central Florida
    1,090
    pull the spark plug and put a marble on the plug hole. if the marble launches two foot vertically when you kick it - your compression is good.
    quiet people seem intelligent
