Results 1 to 10 of 10
Thread: 85 200X Clutch...HELP!!!
    Mar 2007
    Hawaii
    9
    Hey guys, thought I would ask here...
    I recently acquired a 85 200x. I had a 250sx years ago and really missed having a three wheeler.
    I saw this sitting behind someones house and asked if I could have it, they said, "Yes get that rubbish outa our yard!! Please!!!"
    And so i took it home.
    Some weeks later, im at this point.
    Now here is where im stuck.
    Having never done bike motors before im unsure about some of the issues with the clutch throw out that is located in the right crankcase cover.
    When i replaced the clutch and tightened up the 4 springs I noticed that they had to be torqued down quite a bit so that the right crankcase cover fits.
    But, how much is too much? Once the cover is installed how much play should it have before it engages the clutch? Or, should the throw out lever rest against the push rod for the clutch, thereby causing the push rod bearing to spin at all times?
    I suppose it would anyway since once I have the cable hooked on the clutch throw out lever it will be snug... did i just answer my own question? The clutch springs should be adjusted to that when you install the right crankcase cover, the throw out lever attached to the right crankcase moves ever so slightly before engaging.
    Can someone confirm my rantings?
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    PM sent..........
    Aug 2006
    Salt Lake City, Utah
    71
    Well, I can't help much on the clutch adjustment....
    The lever free play length is 3/8" to 3/4" and I the bolts on the clutch center should be torqued to between 29-36 ft.lb.
    I just wanted to add, you've done one hell of a job on that X!!! Wow!! the engine detail looks fantastic!! I see you went a "chopper" style on the cooling fins, black engine, with the edges of the fins polished up!! Man its night and day from when you started!! Awesome job! Awesome!
    Sioux City, IA
    256
    I'm scoping out your garage and wondering what "Romaine Hearts" are.
    "Trikes don't kill people. I kill people."
    www.250r.us
    Mar 2007
    Hawaii
    9
    Mastacator,
    Thanks bru
    It has been a fun project. I have restored jeeps for years but never did a bike before..a whole different world, but its nice to know what you have when you are finished!
    I have the torque specs on the clutch nut (the one that takes the tooth socket)
    But its the actual springs im a bit curious about. How far you tightened those four bolts that go through the springs.
    free play length it 3/8-3/4 eh? wow thats alot of leeway! haha..sounds like im within that!
    Thanks for the info!
    BigRed...
    Romaine Hearts is a certain kind of lettuce
    Gotta keep the goats fed
    Cheers guys
    Aloha
    Noah M
    1985 200X
    Jul 2006
    I cant really remember when I put my springs back in my old x how much I tightended them all I know I spend abotu 45 minutes puting in new clutches tightened everything back up I torqued everything till GORILLA SPEC! and then rode the hell out!
    Oct 2006
    2,502
    Make sure you show the previous owners how the "rubbish" turned out. Great job!!!
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    You tighten those down until they stop and make them snug. That is the four bolts that press the plate that presses the springs down, they go down all the way, right out of the Honda and Clymer manuals it says to do it and I've done it. I am positive that is what you do. The nut requiring the 4 toothed sprocket gets torqued but it sounds like you already have that figured out. FYI the torque spec for that nut is 40-50 N*m or 29-36 ft*lb
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    Jun 2004
    IL
    18
    Solid Snake is right to tight the 4 bolts down intill they are tight. you have compress all the springs down u just start on one and tight a little then go across from it and tight it down. as long as you keep workin your way around they intill they are good and tight.
    i hope this make sense
    Eric
    1984 HONDA 200X MINT COND
    1985 HONDA 350X
    1986 HONDA 200x not run right now
    1985 HONDA 250sx
    1983 HONDA XL100 for parts
    Mar 2007
    Hawaii
    9
    Sounds good, I'll turn em down tight as a tick.
    Thanks fellas!
    Noah M
    1985 200X
