Well not exactly, but it sure looked that way, on the back of my truck.
While everyone was sleeping on Sunday, a 250R poped up on ebay with a buy it now of $1000. I grabbed it.
When I got there, the guy took off another $100, and I didn't even ask him too.
It was sold as a rebuildable trike, but it starts and rides.
So far I see 4 things wrong with it.
Bear with me, I am not too familiar with the 250R.
The resiviour is not mounted, and flopping around.
The clutch does not fully disengage, looks like a cable issue. It is adjusted to its max.
Right in front of the front sproket, looks like the chain came off, and did some damge, there is a repair there, so it will need some welding I guess. I'll have to scrape the repair.
But the thing that worries me the most, is what appears to be a filler cap (looks like the oil filler cap on a four stroke) seems to have milky fluid in it, and that means water could be getting in that area.
I am not sure what that filler hole is for? Gear case fluid? Can water even get in there from the cooling system?
Other than that, the thing screams, and all switches and lights work, plastic is in pretty good shape.
I want to get it good mechanically, and ride it a bit, then I will do a frame-off restoration to it.
Advice is welcome.
