Results 1 to 15 of 15
Thread: anyone ever heard of a rokon?
    kyle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2003
    291
    i was at cycles r us (a boneyard) one day and seen a 2 wheel drive dirt bike. it was short and stocky and called a rokon. does anyone know anything about these bikes? and how the 2 wheel drive works?
    1986 Honda 250SX
    3tigers is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    ive heard of the rokon's and seen pic's before.never saw one in person.not sure how they work.
    Washingtons Crossing, Pa.
    2,977
    They are a classic example of good idea gone bad - you could turn the Queen Mary around in a tighter circle than you can a Rokon - but at least the engine is a Honda
    http://www.rokon.com/products/ranger.htm
    yyz4208@aol.com is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2003
    291
    ANYONE IN HERE SEE THE YZF 2WHEEL DRIVE?
    SE Minnesota
    533
    rokon
    The cool thing is, that you can fill the tires with fuel, or water. They also float if the tires are just filled with air.
    http://www.rokonworld.com/start.html
    83 YT 175
    85 ALT 125
    Apr 2003
    291
    that sounds awesome, how exactly does the 2 wheel drive system work on that thing?
    1986 Honda 250SX
    2,977
    I believe it works via a gear reducer (sub tranny) fed by a conventional shaft/u-joint on the top of the front fender. You can see the chain running from it in the picture. I speculate that since theres no front suspension and therefore no vertical movement to worry about, it only needs one u-joint under the head post mounted drive shaft. Its been 15+ yrs since I rode one and back then I didn't really care how it worked.
    Roanoke, VA
    4,038
    There have been quite a few in Dirtwheels over the past couple of years.
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Apr 2003
    Washington N.H.
    74
    IV'E SEEN ONE IN THE ROAD KILL CAFE, IT WAS BRIGHT YELLOW UP HEAR IN N.H. I HEARD THEY WERE REPRODUCING THEM? HOW TRUE IS THAT?
    IF IT AIN'T BROKE DON'T LEND IT
    71 Honda Z50
    86 Tecate3
    02 450ES
    NEED 85/86 250R
    SE Minnesota
    533
    rokon
    you can order a brand new one today for $4775. There are lots of accesories to add on too. Lots of agriculture stuff such as a PTO shaft. Cool. :-D
    BTW: nice squirrel sack KXT lol.
    83 YT 175
    85 ALT 125
    Apr 2003
    Washington N.H.
    74
    IV'E NEVER SEEN ONE IN ACTION THOUGH, WOW A PTO! DOING SOME FARMING! A BRUSH HOG OR SOMETHING I WOULD THINK IT WOULD BE A LITTLE AWKWARD. IMAGINE SEEING THAT PULLING A BOG HARROW OR A PLOW YEAH THEM SQUIRRELS ARE BIG UP HERE :shock:
    71 Honda Z50
    86 Tecate3
    02 450ES
    NEED 85/86 250R
    FullBore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Looks like you can do anything with one of these, they do disc harrows and 3 point hitches and all sorts
    http://www.rokon.com/products/accessories.htm
    1979 Suzuki TS100
    1984 ATC70, Broke
    1984 ATC110, Repainted and Rebored.
    1990 Suzuki SJ410
    Unsuspended Antics.
    2,977
    Yo KXT, I know the Roadkill Cafe very well - my parents have a house in North Conway. I've spend many a winter as a ski bum in your neck of the woods.
    May 2003
    6
    I have a couple of them. I just got them within the last month. It is the most go anywhere machine I have ever owned. It is so fun to ride! I will be fixing one up with a Honda ATC 125M engine in place of the two stroke it came with. They have no suspension other than the spring seat and the big fat tires that run about 2-3 psi. The tires really work pretty well for suspension. There is a double u joint at the stering head and an over running sprag type clutch in the drive line so there is no bind up.
    For more info look them up at www.rokonworld.com
    Apr 2003
    291
    i want to ride one!!
    1986 Honda 250SX
