Can you identify this pipe?
The rear motor mount were the swing arm bolt is and all, I thought those brackets were steel. not aluminum like this one?
The front forks on this, are they stock or like a 350x? same question on the brake caliper thats for these forks.
ha ha check out the boost bottle and intake.. pure performance eh''''''. ha ha ha
also got a 300kit. head, cyl. piston and rings. need head gasket and looks like studs. ill have to search for what you all use for head gaskets, and rings?
here are some pics.
