Thread: Anyone Use PERMATEX Form-A-Thread???
    Sep 2006
    S.E. LA
    700
    Question Anyone Use PERMATEX Form-A-Thread???
    I just bought a Kawasaki Mojave 110 in great shape for $50. It has 2 problems, a stripped spark plug hole and supposedly no spark.
    I did a search here and besides the helicoil I saw a Permatex Fix-A-Thread. It's real cheap and says no drilling so I thought I would check it out.
    I'd like some input from those that have used it.
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    I have a tube but never used it. I just don't trust it, but it may work great. I always opt for the helicoils...
    Sep 2006
    S.E. LA
    700
    Can you tell me how it is supposed to work? Do you squirt it in the hole then use a plug to make the threads?
    I've never had to fix a messed up thread.
    '04 EZGO TXT
    Former trikes;
    I imagine it's a 2 part epoxy with a release agent. If I can find it I'll post the directions. Remember, if that crap doesn't work it will fall into the cylinder and valve area. I wouldn't use it in that application. I'd grease the hell out of a helicoil tap, tap it and then flush the topend. That would be a safer permanent repair. About 45$ for the kit....
    Sep 2005
    FL
    855
    From what I have read on diesel and other sites that stuff work pretty good. I have never used it though.
    "In a society that tries to standardize thinking, individuality is not highly prized." -
    -- Alex grey
    Mar 2007
    Howard Beach, New York, United States
    687
    if you use the permatex, you should do a rebuild of the engine and use the permatex while the engine is apart to see if it works and so nothing gets in the engine, a rebuild would be a good idea anyway if you got the quad for $50
    Current Project:1978 Pontiac Phoenix 355 v8
    Past Bikes: 1999 Yamaha Big bear 350, 1981 Yamaha XS 400, 1996 Yamaha yz250 1984 Honda big red, 2004 Xtreme cr107, 1999 Yamaha bear tracker, 1999 Suzuki ds80 STOLEN, 2005 Kawasaki klx110, 1986 Honda trx200sx
    Daily Driver: 1990 Buick Electra Park Avenue 3.8 v6
