Results 1 to 10 of 10
Thread: 86 250r crankcase oil
    toyvette81 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    durham
    284
    what kind should i use. i just bought the 3 wheeler yesterday and it does not have a dip stick just a cap and what was on that was a grey/green looking oil im thinking it has water in it but i hope not. how much does it hold also thanks....
    1981 Corvette (chevy bright white)
    1998 GMC shortbed step side lifted,35's,mickey t's
    1995 Monte Carlo (gas mileagle car)
    1987 XR100
    1989 Polaris Trail Boss 250 (old reliable/faithful)
    1984 ATC 110 (Blue)
    1985 ATC 350x (DG exhaust)
    1986 ATC 250r cleannnnnnnn
    2002 polaris scrambler 500HO 4x4 (supertrapp exhaust)
    75 jeep cj5 6" lift, 35" procomps, locked up,
    77 jeep cj5 3" lift, 34" tsl's
    67 jeep comanche(running soon)
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    I've been using the stuff from Honda for the CR's and 250R's.
    That's what the guy suggested, and it works well. About 6 bucks a quart.
    It's 80/85W, Racing transmission fluid, but don't start thinking thick..........it's nice and thin. You could also use the stuff from Royal Purple, or motorcycle engine oil.
    On the clutch side case, you will notice an oil check bolt, towards the bottom, and to the rear of the waterpump cover.
    Remove that bolt, and add fluid till it dribbles out the hole, and re-install the bolt, and fill cap. That's all there is to it. It should take a little over half a quart.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    May 2007
    Orange County, NY !
    1,672
    I recieved that same oil from my local repair guy, but in the Honda manual, it says to use 5W, 10W30, 10W40, 20W40, 20W50 depending on the temperature. So I am confused about which oil to run.
    I also saw the gray fluid on the cap, and thought it was water from the cooling system, but when I flushed and drain it, the oil did not appear milky at all. It seems only that gray color collects on the cap.
    Sabula,IA
    620
    It's gray/green because of the aluminum clutch plates. Sounds like it's been in there a while.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    The OEM motorcycle oils are rated differently some how, and their 80/85W is more like a normal 10-20wt engine oil. Me personally, I run ATF in the transmissions on all my 2 strokes.
    Sioux City, IA
    256
    I've got Synchromax from Royal Purple. Of course, I actually have to have some riding on this bike for my opinion to mean anything. Well sell the crap at work so I just put it in everything. Try buying a case of 80w90. $$$
    "Trikes don't kill people. I kill people."
    www.250r.us
    durham
    284
    thanks thats what the guy gave me at the shop
    1987 XR100
    1984 ATC 110 (Blue)
    Sabula,IA
    620
    Man, ATF's awful thin for summer temps. It's like 7 weight, I believe.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    36PJ Keihin
    K&N
    Boyesen reeds
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Live Oak, FL
    15,069
    Yeah...its got some nice friction modifiers for the clutch though, and its thin enough it gets into all the nooks and crannies of the trans, thats my theory anyways. I did believe it or not actually notice a difference in how fast the engine revs vs 30wt, I guess bearing/counterbalancer friction difference?
    Sabula,IA
    620
    I would think more clutch pack. That's a large rotating mass that runs partially submerged in the oil. It probably would make a noticable differrence.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    36PJ Keihin
    K&N
    Boyesen reeds
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
