Im thinking of building an auto x I have the 200x roller and the 200s engine is there any other parts that I'll need and how much modification is involved.
As far as I know and read on here you will need, intake manifold, exhaust, and engine mounts I think, also youll need to rig the brake lever somehow.
1986 200x- old school D.I.D wheels, Gold D.I.D X-Ring Chain, Rad MFG. Carrier, PRM Grab Bar, Pro Circuit T-4 custom, Maier plastics, 85x forks, 18x10.5x8 kenda klaw mxr's on itp steels, the money pit never ends![]()
Stock 200X engine mounts will work, I believe. 200X exhaust and carb will be a good idea to use (the exhaust you MUST use, carb is a good mod instead of the 200s carb). Rear brake lever will indeed need to be rigged, but it's not that hard, just some bending and linkage work.
I'm back in the USSR...
Thanks for the info I will probably get started on it tonight I have everythig except the 200x silencer.
you will need to mod the foot brake and extend the shifter. also use a 200x intake manifold on the 200s engine. other than that its a direct bolt in.
down to parts because i no longer have a place to ride trikes.![]()
GIT IT RAAAGGGGG !!!!
actually you have to shorten the 200s shifter
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
ooo yea lol. i had to extend the x shifter. lol never mind me.
