Where do i add oil on my 84 200s?
Where Do i Add (refill) oil for my 84 200s? Do i add oil where the dip stick is at? post pics if you can....
yep....where the dipstick is.....on the right side (obviously if you know where the dipstick is)....to check the oil level...place it on level ground, dont screw the dipstick in...just set it in there and wait like 3-5 seconds then pull it out....i believe there are X looking things on it...it should exceed the X's....after you add the oil, wait a few minutes for the oil to settle then check it....
Moving this to trikesylvania, for future references, please keep trike related posts there.
//ArrowChat Integreation Code
