Results 1 to 10 of 10
Thread: tri z coolant//rads
    HEAD09's Avatar
    HEAD09 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    NH
    433
    tri z coolant//rads
    well i flushed it out looked at the impeller and it looks fine...but my question is it???it turns fine but ive seen that a few of you have change them over too the aluminum ones...also the thermostat(is there one in there?can you bypass it?) i thiink has a wire off of it when it over heats the bike will shut down??
    springville, PA
    6,185
    thermostat is under the air box housing and the bike wont shut down but the red light in the headlight will shine letting you know its overheating.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Columbia
    5,131
    Ronnie (Yamahondaman) makes the aluminum coolers, as well as the pimp bi-pass thingie to replace the thermostat.
    A lot of people change to the aluminum ones because the stocker is known to fail. If you decide to stick with the stocker, I would get a nice little temp gauge that hooks up to the fluid line.
    Im going to hook up with something like this soon. Then you can know FOR SURE that your bike isnt overheating.
    http://cgi.ebay.com/ebaymotors/ATV-S...spagenameZWDVW
    springville, PA
    6,185
    yeah the guy with the outframe pipe on his tri-z had one of those suckers
    Nate
    R.I.P HRR
    HEAD09's Avatar
    Apr 2006
    NH
    433
    so whats the average temp....and thats thing is cool...
    Jan 2004
    Palmetto,Florida
    2,300
    03shee .. "Nathan" knows the temp .. , i think he said 150-170 deg. ?
    "07" DR650 Suzuki Dual Sport
    Rennat_2006's Avatar
    Rennat_2006 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2004
    194
    What temperature does the redlight turn on at anyways?
    -1983 Honda ATC110-
    Brand new topend using. Performance cam and some porting/polishing.
    Should be good for another 24 years now!
    -1991 KTM 540-
    Piston turned into grenade inside motor ammit
    -1996 KTM 550-
    Midway through COMPLETE rebuild
    -1997 Honda Cr80-
    Spun crank bearing on trans side ammit
    HEAD09's Avatar
    Apr 2006
    NH
    433
    now i want to know...you got me curious...has any one seen it go on...
    Jan 2004
    Palmetto,Florida
    2,300
    WELL ??? back in the 80's when the light would come on IT WAS HOT !! iv'e only seen it once.... prolly like a car dummy light .... ummm ... 200 deg. ? by then it's too late and some damage has been done....
    ColeTrickle's Avatar
    ColeTrickle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    New Hampshire
    247
    "The thermostatic valve should begin to open at 63-67c (145.4-152.6f)" says my service manual. I have seen the light come on and let me know before I did any real damage. The last time it was winter and I was ripping it across some corn fields when the red light came on. I slowed her up and could tell she was getting Tight. After a brief cool down she was back running. Since then the top end has broken in more and that hasn't happened again
