Not a bad score, $50 from Craigslist
Doesn't run, but pulls over, so I set to strip it down and begin effecting some repairs.
The interesting thing about it is that it's got a Comet clutch (a la mini bike), and is set up to accept just about any motor you can bolt onto her. This is the only 3 wheeler that has this type of design from everything I've read. Have a look
This is the engine mounting plate with the engine off. See all the mounting holes? Cool! Something that can be kept running indefinitely by yanking a motor off of just about anything.
Took me all of about 15 minutes to strip it down to get to work
It even has a forward and reverse gear, that's controlled back here at the gearbox
Now I'm thinking that it's time to go pick up that Ariens rototiller that my dad offered me and "borrow" the engine
The engine that is on it now is a Kawasaki FG300D industrial 7.5 HP, that I can find absolutely zero informaiton about on the net. It pulls over with about 65 psi compression, which I don't know if is normal, I'm thinking that's pretty low. A telltale sign is that somebody used a piece of foam in the air cleaner, which is fine, but it looks like they scraped a bunch of dirt and gunk off the inside with a screwdriver. Not good. But, I'll toss on a Briggs or something and have her going for the summer and tear this motor down over the winter. It'll give me something to do![]()
