wet with oil?
behind the kick start lever the seal is dripping a little oil is this a bad thing or should i not worry?not much just enough so that its wet.anybody have this happen to them?
85 tecate 86lt250r
85atc 200x
As long as you keep oil in it there should be no problem, but I would just go ahead and replace the seal and solve the problem, seals are usually very inexpensive
Airfoolers RULE!!!
that what i thought to its not bad but thought id ask anyways.thanks.
85 tecate 86lt250r
85atc 200x
If I remember right, that seal can only be changed from inside the clutch side case. Maybe get a seal and wait till the next time you have to open it up to change it.
>>>>>>>>>>>>>>>2007 Yamaha Raptor 700R>>>Cross Country Racer<<<<<<<<<<<<<<
www.myspace.com/bluelionracing
Support my 2009 sponsor:
For all your ATV suspension needs.
the price of preventative maintenance is alot cheaper than the alternative any day
yeah im going to replace it when i rip her open some day to make her more insane then it is now.
85 tecate 86lt250r
85atc 200x
//ArrowChat Integreation Code
