Thread: paint color? chappy red..
    any color out there in a rattel can close or the same to chappy red??
    fatcat is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2005
    tn
    247
    can you show me an example?
    if its like the frame on my bw 200 high heat red by duplicolor is close. i think i spelled that right
    My rides
    MINT 1986 bw 200
    any yamaha red frame is that color.. ya a BW is the same color
    Apr 2009
    Redwood Coast, CA
    I have recently been searching for this exact same paint color for my '86 YZ250. I felt I had to sign-up here to share this info after a Google search displayed this thread. I have found two "" products that are extremely close. Both are available at either ACE Hardware or TrueValue.
    Valspar Anti-Rust Armor "Gloss Red" #21927
    X-O Rust "Hot Red" #XO-41
    The Valspar paint is higher quality and a bit more durable than the X-O rust paint. The Valspar is just a slight shade "redder", or deeper than the OEM Yamaha color. It has better gloss and flows out (less orange-peel texture) better than the X-O paint. Very slow drying.
    The X-O Hot Red is damn near a perfect match. Slightly orange tinited just like the the OEM Chappy Red. Scratches/chips slightly easier though. Dries quickly. This paint would blend in alittle better for spot touch-ups on a 20+ year old faded frame.
    Want to take it to the next level? ICI/Devoe Devguard 4308-9000 "Safety Red" factory pre-mixed industrial enamel in a gallon can. Yes, it's a brushed on paint but could be sprayed. It is ridiculously durable, far beyond anything rattle-cans can provide. It's designed for professional painting contractors but is available over the counter to the general public. Only costs about $33 a gallon! Not a direct-to-metal paint, must be primed first. The color is basically identical to the Valspar paint mentioned above, nearly a perfect match! Several day long dry time.
    Or you can spend the big-bucks ($250 last time I checked) to powder-coat it. "Red Barron" was a color name I remember from a few years back, not sure of the brand of powder. Guy told me it was a "two-stage" coating with a clear! Must be baked twice, I guess.
    Hope this helps.
