Are all 200X/300EX/350X/250R/400EX wheels center offset?
Are they all 8 x 8?
Are they all 8 x 8?
You could get 9x9's that will be offset 3x6
400ex wheels are 9's right? WHats the offset?
WHat is the measurement of the bolt pattern of a Honda 4/110 hub??
Is it 110mm from center to center of stud holes?
Its from the outside edge of one stud to the center of the opposite stud.
I'm back in the USSR...
I dont think that is right.
Here you go. Should have googled it first off.
https://www.rsracing.com/tech-wheel.html#patterns
Well, Dennis Kirk told me that's how to measure bolt pattern. I guess he LIED.![]()
i thought it was center to center of the studs ? but anyways i had 9x9 ams rims with 3+6 offset i looked threw a ams book and there were a pair of 8x8 rims with a 3+6 offset with a 110 bolt pattern as well.
down to parts because i no longer have a place to ride trikes.![]()
GIT IT RAAAGGGGG !!!!
Are all honda trike/400ex and 300ex wheels the same? Which ones are aluminum with the greatest offset?
__________________
'85 ATC250R
.030 Over Wiseco
FMF Pipe/Answer silencer
36PJ Keihin
K&N
Boyesen reeds
Magura hydraulic clutch
Roost Boost
MSR bars
OMF swingarm skid
ITP Beadlocks
Three Wheelin' Since '84
200X wheels are 4+4, 300ex through 450R are 3+6? Anything with a wider offset available in 4/110?
Nope all you can get is a 3+6.. there are 5x5 but that gives you inset instead
I've never heard of 2+7; it would probably be too weak.
__________________
'85 ATC250R
.030 Over Wiseco
36PJ Keihin
K&N
Boyesen reeds
Roost Boost
MSR bars
OMF swingarm skid
ITP Beadlocks
