Results 1 to 3 of 3
Thread: spark problem!!!!!
    Feb 2003
    65
    spark problem!!!!!
    when i kick over my 86 250r, i get spark.....sometimes
    i am only getting spark on like every third kick. i checked for loose connections, my flywheel is fine and my plug is not fowled!
    if anyone has an idea, please help me out . this ones gonna kill me if i dont solve it soon!!!
    kimmer250r's Avatar
    kimmer250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2002
    North of Swinehart, West of Mik6
    411
    Cali,
    My friend is having the same problem with his 85 right now. His was the cdi. He's some specs to check to help you narrow it down.
    ignition coil---primary coil resistance 0.16-0.2 ohms
    ---secondary coil resistance 3.69-4.51 ohms
    (without spark plug cap)
    Exciter coil resistance--- 50-250 ohms
    pulse generator coil resistance--- 50-200 ohms
    lighting coil resistance--- 0.1-1.0 ohms
    ac regulator---regulating voltage 13.5-14.5 V
    ---resistance 100k ohms
    hope this helps.
    Kimmer
    THERE FROM THE START-HASPIN VET 2002-2003-2004-2005-2006-2007-(missed 08-dang babies)-2009-2010-2011-2012-2013 AND ALL THE REST!
    1985 Big Red
    198? Kawasaki KLT 250
    19?? ATC70
    "Secret Project" Tiny Titan
    2010 Polaris Crew
    Mar 2003
    West Monroe, LA
    847
    If the trike is running fine I would not worry, I have 3 250R'S and they all do that. I had my bro kick my 85R over for me ( i thought the spark was my problem but ended up being bad carb) in a dark area and mine would only fire every 2nd or 3rd kick so I checked my 86R that runs like new and it did the same thing. Makes no since to me because it will fire up 1st kick just about every time.
