does anyone use the synthetic radiator juice in the rads? can you or what is the best stuff to use...
I've personally always used the regualr antifreeze... the green stuff has always worked fine for our bikes.
same here, just throw in some anti-freeze. havent had a problem with it.
i always used just regular rad fluid in my sleds. no diff than a trike rad.
down to parts because i no longer have a place to ride trikes.![]()
GIT IT RAAAGGGGG !!!!
it just i have the orange stuff here and would like too use it ...but i didnt know if i could..did want to go to the store to get the green...has anyone just used the the purple ice???
I use the orange stuff since thats what i use in my trucks, never had a problem and i dont think there ever will be. Im not sure what the difference is between the two, never really thought about it.
The green is ethelyne glycol based,and the orange is propylene glycol based.I cant tell you what that means![]()
But do not mix the 2 togethere.They have different gravity rates.Meaning one type is heavier than the other.
The orange stuff is junk.It cuases big problems in cars.It tends to cuase more corrosion especially if the system runs low and mixes with air.
Proudly NOT a member of
"Team on the Teat"
ya what he said ...i would drain it and use reg fluid
350 stock cyl drag banshee
85 yamaha tri-z stretched and powered by a SPROCK RACING big bore on alky baby ..yes its fast and no you cant ride it ...lol
86 atc 250r
86 350x
????? who knows what else ?????
and if you want to take donations i will stay home !!!!
You also want to use distilled water, not tap water. Tap water is full of contaminants like lime, etc. These minerals will eventually separate from the water and start to accumulate inside your cooling system and eventually inhibit flow. Distlled water does not contain these minerals.
I'M GETTING TOO OLD. IT TAKES ME AN HOUR AND A HALF JUST TO WATCH 60 MINUTES.
'85 Big Red 250es (Beer truck)
'85 350x
'85 250r
'84 ATC70
'01 Yamaha Warrior 350
'05 Honda Recon 250
Always looking for more!!!
'05, '06, '07 TF survivor. Looking forward to '08!
I've used it, but not for any long periods of time. I run Engine Ice in everything of mine now, great stuff.
Great info, after reading this maybe ill swap it to the green stuff.
I use "40 Below" at the recommendation of some board members to try to keep my motor cool. It really runs hot.
the orange stuff is dex cool..for cars with alum. blocks and heads..it junk and will only last a year at the most! then it turns into a dark brown sludge/slime,,,and clog's stuff..its ok for temporary but switch out with the green with distilled water.. engine ice and 40 below are both great stuff
