ineed to tighten the chain on my 85' atc70, how do i do it?
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
I had the same problem with mine - see the sig. So I took it in to the honda dealer. They told me that the chain that is used is special and that you cannot tighten it and that I need a new one! Keep that in mind. If you are in canada, they cost around $80. Just thought I'd let you know.
1985 Honda Atc 200M
Chain drive with no reverse, but has electric start!
The chain is adjustable. I don't have the manual here in front of me either. So.. Going from memory the adjuster nut is inside the frame in back. You need to loosen the nut and push up ( I think ) to tighten the chain. Tighten the nut back down and your done.Originally Posted by Honda atc70
Howdy
If I remember right, I think after you take the chain cover off they have a chain tensioner that you adjust instead of moving the carrier. Its been a while. I also seem to remember a point where you run out of adjustment, but if you take a link out its too short, too, but #420 chains are so cheap it was easier to replace it.
