Ok, here it goes.
I heard that 2 strokes require more compression than 4 strokes to run. Why us this so?? Please give me a detailed and technical answer if you have one.
Also when my compression is this low should it make my bike run crappy or just with less power. My reasoning behind this is that my Atc200 is at 120psi, doesn't have a lot of power, but it runs smooth, never misses a beat. On the other hand, my 250r (also running at 120psi) it runs really blotchy, pulsing, sputtering. (I am still working on my jetting as it is running a touch rich) Will this low of a compression in a two stroke make it run crappy, or should it still run smooth, just with less power??
Disclaimer-before anyone says anything, please just answer the question at hand and not try and diagnose my bike, as I have already gone through the proper checklist of things. i.e. air filter, exhaust, reeds, plug chops, carburator, petcock, fuel, oil, etc... This is not intended to be mean as I do appreciatte any help, it is just meant to get everyone up to speed and on the same page so we can aviod the "beginners engine diagnosise 101" stuff.
From all the reading i've done i've decided I want to replace my crankcase gaskets, or at least the left side to be safe. This is the seal or that is in the crankcase assembly itself right next to the bearing, correct? Is there any easyway to do that in a day, or will I have to remove the engine, split the case etc...If some one could give me some insight on this it would be greatly appreciated.
Thanks for the help![]()
