Results 1 to 11 of 11
Thread: 250r PROBLEM
    Oct 2005
    Ely, Minnesota
    29
    Exclamation 250r PROBLEM
    just put the motor back together and started it up and ran fine then after a little while it seems like it jumps into first gear and dies it will roll after it dies so it is not in gear if you hold the clutch in this does not happen it will drive if you put it in gear but im afraid to drive it because i dont want to break anything anyone have any idea why this is happening?? THANKS Bryan
    85 ATC 350x
    86 ATC 250r
    85 ATC 250r
    84 YTM 225DXL
    85 ATC 200x
    84 ATC 200s
    83 ATC 200
    83 ATC 185s
    81 ATC 185
    84 ATC 70
    Was your clutch perfect before? Sounds like the basket is grooved up a bit or something is worn out. If you split the cases and something in the tranny was wrong, you'd know it in the first 10 minutes.
    Oct 2005
    Ely, Minnesota
    29
    I put in a brand new hinson basket and new plates the case was split but i never touched the tranny
    85 ATC 350x
    86 ATC 250r
    85 ATC 250r
    84 YTM 225DXL
    85 ATC 200x
    84 ATC 200s
    83 ATC 200
    83 ATC 185s
    81 ATC 185
    84 ATC 70
    jadleybray's Avatar
    jadleybray is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    oregon
    352
    if the spring(s) in between gears in the tranny are wore out, it can cause this also.
    Quote Originally Posted by jadleybray View Post
    Hmmm, what model has springs between the gears in their tranny??
    Jackson MI
    1,688
    Is It possable that one of the shift forks Is not lined up Into the groove on the trans gear? The unheld gear might be vibrating over Into another gear then shutting the engine off. Just a thought.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Oct 2005
    Ely, Minnesota
    29
    That is what i was thinkin but wanted someone elses opinion before i split the case ill take a look and let you know thanks bryan
    85 ATC 350x
    86 ATC 250r
    85 ATC 250r
    84 YTM 225DXL
    85 ATC 200x
    84 ATC 200s
    83 ATC 200
    83 ATC 185s
    81 ATC 185
    84 ATC 70
    I would pull the clutch cover and clutch. Get a bolt that fits the center of the clutch main shaft. Chop the head of the bolt, put the rest of your bolt in a cordless drill and put it back in the mainshaft. Spin the shaft slowly with the drill and shift through all the gears. I do a "dry run" with all my trannies. It is very easy to do and a quick check that everything inside is operating correctly. It isn't under any huge force either so there won't be any damage to the internals if it's wrong.
    Steve
    L'Anse, Michigan, United States
    140
    dirtcrasher>> can you do that on automatics too? like a 250es
    Course you can, the clutch on an ES is on the mainshaft and the crankshaft has the centrifical clutch. Yank them off and go to town...
    Did either of you guys try the "dry run"?? I posted?? Let us know what you found...
