Thread: triz fuel system
    HEAD09's Avatar
    HEAD09 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    NH
    433
    triz fuel system
    not get fuel to the carb....i took off the fuel line and nothing....flipped thr res/on both ways and nothing...and it full (oh which way is the arm go...up for res down for on??) and checked the fuel filter...what else do you have too do...thx
    Pa.'s Highest City
    8,058
    Is your fuel pump working properly and all the lines hooked up correctly?
    HEAD09's Avatar
    Apr 2006
    NH
    433
    yes they are...it was working fine...how do you check the fuel pump?so unless its turned over there shouldnt be any fuel flowing is that correct?
    Columbia
    5,131
    There should be a vacum hose going into the rear of your fuel pump, that is connected to the base of the cylinder. This is what makes your fuel pump pulsate, and send fuel everytime the engine makes a revolation.
    Hook your lines up going to the fuel pump, put it on either on or reserve, leave the lines going to the carb off, and kick it a couple times. If nothing happens, your fuel lines have a clog, or your pump needs a rebuild.
    HEAD09's Avatar
    Apr 2006
    NH
    433
    okay...ill try it...thx
