Page 28 of 36 FirstFirst ... 18 26 27 28 29 30 ... LastLast
Results 406 to 420 of 538
Thread: Top Tier Tri-z - REINCARNATED
  1. #406
    Aug 2005
    Lockport, NY
    2,395
    I have something bigger and better planned for this air intake but I am waiting on some parts to make it happen. In the mean time I have devised this. I used the stock airbox boot but reversed it. The problem with running a PWK 39MM is that the bell is 2.4375 or 62MM. Not many air filters fit it and forget about buying any silicone adaptors to fit it. Oddly enough the stock boot fits it like a glove when reversed. Leaving the other side 2.250 or 57MM. From there I used a piece of 16 guage 304 stainless exhaust pipe 1.250 in length to adapt a UNI filter on. It fits perfectly under the seat. Just need to relocate the overflow bottle now.
    Purchased these prototype guards from Marco / Hagen / Greenboy here on the boards. Wanted something different. Every screen/guard I bought the pins were half worn out. These look killer.
    New Radiator cap too.
  2. #407
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Are OEM fork boots still available?
  3. #408
    Apr 2008
    somerset ma
    1,822
    That thing is looking awesome Jeff, really nice machine for sure
    The only problem I can see in those pics. is,,, I can see your damn "Man Feet" in that stainless cover!!! "Nothing worse than seeing another guys feet!!!
  4. #409
    Aug 2005
    Lockport, NY
    2,395
    no dog they are not. tanks loves the man feet.
  5. #410
    Apr 2008
    NW, IND.
    842
    That is the best looking Tri-Z I've ever seen. Good Job! Not much into Yamahas but that one looks cool. Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
  6. #411
    Aug 2005
    Lockport, NY
    2,395
    Thanks Beets.
    She will be coming out of the basement this week... Almost ready to fire...
  7. #412
    you wont like it when the air filter oil is all over everything.... get a outerware...
    that Chit looks tough!!!!!!!!!!!
  8. #413
    Aug 2005
    Lockport, NY
    2,395
    Good point BR I will get on it like white on rice in a snowstorm.
  9. #414
    Las Vegas, NV.
    2,504
    Looking very nice!
    Why bother if this intake setup is only temporary?
  10. #415
    Aug 2005
    Lockport, NY
    2,395
    Guys I am looking for the diameter of the lower chain roller? I purchased a 38MM roller or a 1.5 inch roller and it appears to be too large??? So I need to know what size to get. My original was not present when I purchased the trike.
  11. #416
    Aug 2002
    NY
    2,652
    I have an extra oem one if you want it.Ill throw it in the box with the calipers.Mike
  12. #417
    Aug 2005
    Lockport, NY
    2,395
    Sweet Mike!
    I'm thinking its either 32 or 34 mm in diameter.
  13. #418
    Aug 2005
    Lockport, NY
    2,395
    Well I spent pretty much the whole day kicking this thing. That big bore motor has my leg feeling ready to fall off. I got it to run for about a minute and a half. Then it shut off and gas came flowing out of the vents on the brand new PWK 39...
    I have good spark (provided by a freshly rewound rickystator)
    I have fuel (Sunoco 110 OCT mixed 40:1 with Klotz ST)
    I have the fuel lines run correctly. (all brand new grey tygon line)
    I have a NOS fuel pump.
    I have a sprock intake.
    I have the vacuum line hooked up properly with a hose clamp on the barb.
    I have the kill switch on run ( yes I have checked spark both ways.)
    I am running a 55 pilot, 170main air screw at proper setting per manual.
    Tried brand new spark plugs (B8ES)
    I have even tried putting a little gas in the cylinder... NOTHING...
    RAFFA>!>!>!>!
  14. #419
    Internet
    1,251
    Geez that blows bro!
    You say gas came pouring out the vent lines of the carb?! Did you have to shut the fuel off to get it to stop? Is it still doing this when you open up the fuel shutoff?
    Be careful with that .. if too much fuel builds like that it could in the engine and seep down into the crankcase.
    The 1:30 you had it running - how did it sound/look - excessive smoke? Sound pingy like a 125cc or a lazy sound?
    (wait - this is not a honda engine - maybe I should shut up as it might not have the same principal makeup as a Honda)
    Regardless - I hope you can work out this lil engine gremlin asap ... that bike needs to be running! Work of art!
  15. #420
    Internet
    1,251
    Just to try, I'll throw it out there ... up to you.
    Take plug out - hold throttle open and kick it over 20-25 times. Turn on the fuel long enough to get the carb bowl about full & shut the fuel back off. Put some gas or starting fluid down the plug hole and then install a fresh new plug.
    Try to start it and see if it makes an effort.
