well im glad i found this site cause everyone around here tells me its fine to run without the filter, lol thanks..
any other input on this?
yeah running it without anything to filter is VERY VERY BAD and will cause your problems with being to rich.
My Stable:
2007 ARCTIC CAT DVX400![]()
07 Kawasaki Ninja 650R--My Baby--![]()
Honda 200M with a 200E engine and 200S front end- A true stump pullerSOLD!
Scars are a reminder to the old of all the dumbshit they did while young - Me
I live in the south and it's very dry and dusty where we ride so on all of my machines I also run a ladies stocking over the foam. Just helps trap what's small.
1984 Honda TRX200
1985 Yamaha 200ERN ( two of these now)
1985 Honda 250SX
1991 Suzuki LT230
2003 Honda Rancher 350ES
never heard of no filter causing it to run rich? But it is very cheap insurance as is keeping the lid on the box. Unless you are going to drag race it, I'd leave the box intact
thx for the info guys ill be sure to get a filter for it! no filter would make it run rich?...wouldnt no filter cause it to run lean if anything?
Yeah man, you always want to run a filter. The last 3 trikes I've bought have not had one either! Since yours does not have a filter, the carb definitely will need cleaned. I soak my carbs in carb/fuel injection cleaner for 3 days, then clean them. Make sure you run something fine through those tiny holes in the jets, then blow them out with compressed air or with an aeorsol can of carb/choke cleaner. Take your time when cleaning the carb and do it right - and do it over a clean hard surface in case you drop something. Also, a small $3.00 fuel filter is cheap insurance to guard against dirt entering your carb through the fuel syastem, even with a plastic tank. Get an air filter on it asap, then clean your carb. I'll bet it runs/idles right after that and you'll lose the black smoke without making any jetting changes. I had this exact issue with my 350x when I bought it. Put filters on it, cleaned the carb. Now it runs like a raped ape. Good luck and let us know.
I'M GETTING TOO OLD. IT TAKES ME AN HOUR AND A HALF JUST TO WATCH 60 MINUTES.
'85 Big Red 250es (Beer truck)
'85 350x
'85 250r
'84 ATC70
'01 Yamaha Warrior 350
'05 Honda Recon 250
Always looking for more!!!
'05, '06, '07 TF survivor. Looking forward to '08!
thanx for all the input guys ill be sure to get one on there asap then clean the carb, it already quit smokin tho after i got that throttle issue figured out but im sure it will idle and run a helluva lot better after that, will keep u updated..
thanks again,
~Stoney~
