Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: Want to build custom mini trike, need advice.
    Sep 2005
    Lipetsk, Russia
    2,824
    Try to find a secondhand Kitty Cat motor. Those things have some real pep to 'em. I just don't like the centrifugal clutch they have stock.
    I'm back in the USSR...
    May 2007
    Orange County, NY !
    1,673
    Quote Originally Posted by hondahaulic View Post
    oh and by the way, what alll needs to be done to a weedwacker to convert it to alchohol? im curious lol
    There's a couple things you have to do, or can do.
    One is to increase the jet size. Also some carbs are not compatible with the alcohol, and the rubber in them melts away.
    The other we do for these engines, is remove the flywheel, and magneto, and put an electronic ignition for gas, or convert them over to glow power, with an adapter in the head, to hold the glow plug. You need a battery to start it, but then thats it.
    Without the flywheel, you get ride of a whole bunch of rotating mass.
    There is a forum dedicated specifically to it.
    http://www.rcuniverse.com/forum/forumid_92/tt.htm
    There is a wealth of info there.
    May 2007
    Orange County, NY !
    1,673
    I think I found place to buy the axles, and I am looking at those lifan 50cc motors, with auto tranny. For $200 it may be worth it.
    http://www.rnrfabrication.com/flexproofaxle.htm
    May 2007
    Orange County, NY !
    1,673
    tamworth,nh
    35
    use a 4 stroke motor for the torque. 2.5-5 is fine. use a gocart axle setup. the bearings should be close as possible to the wheels,but don't have to be right at them. use live axle,forget the atv axles(too heavy and makess you adapt to them)i'm building a raked chopper with a 2.5 tecumseh for my daaughter this way. feel free to write me for details or pics. digger
    osoyoos bc canada
    1,057
    thouse pocket quads use about the same power you want to use you should go faster than the quad using the same rear end since you would have less weight and i would convert one of thoues motors to keep the clutch its even been done already
    Lancaster, PA
    1,738
    "bringin back the oldies"
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    May 2007
    Orange County, NY !
    1,673
    haha, yea real old. I just bought a tri-zinger instead. Finally got it running the other day we have been having a blast with it. Doesn't move my fat ass around too well, need a running start for most hills, and forget about trying to start off in the woods without a push first.
    tamworth,nh
    35
    weedwhacker motors BELONG in an rc plane,lol.
    May 2007
    Orange County, NY !
    1,673
