If it's got miles on it I'd just replace the mains. There should be zero up and down play in a crank but even if there bad, they'll seem to spin great.
It's a 250cc racing 2 stroke, I do about 2 pistons to every one bottom end rebuild.
The waterpump has 2 seals, a water seal and an oil seal. One of them is a mechanical seal with a ceramic face so it's easy to spot in a kit.
If that other side case is worn then it's replace the case or sleeve it. A sleeve requires the case to be split and then set up on a milling machine. The center of that bearing is found and then they can use a boring head and bore it out to whatever is needed. That bearing originally had a close tolerence fit I'm sure - just a couple of thousandths. When the motor gets worn it gets a bit looser and can be used to a point. 1/16th or .0625 is way too much clearance and if a shim is used and it falls out, your in trouble.
All bad news I know... Sorry....
