Thread: mikuni 32 mm carb on a tri-moto?
    trimoto.125's Avatar
    trimoto.125 is offline At The Back Of The Pack Arm chair racerFirst time rider
    kingston
    191
    Hi everyone, I was wondering if it would be ok to run a 32mm mikuni carb on a yamaha tri-moto 125. I think the stock carb size is 20mm but i am not sure. I don't have the stock carb, but i had a 32mm carb lying around so I thought I wondering should make use of it. The motor on the tri-moto 125 has also had some top end modifications but i am not sure what they are. The point I am trying to get to is will the jetting of the carb work with the top end modifications?
    Mar 2007
    Williamsport, PA/Lycoming county
    829
    no, it will be WAY to rich and probably not even work fitment wise anyway.
    My Stable:
    2007 ARCTIC CAT DVX400
    07 Kawasaki Ninja 650R--My Baby--
    Honda 200M with a 200E engine and 200S front end- A true stump puller SOLD!
    Scars are a reminder to the old of all the dumbshit they did while young - Me
    kingston
    191
    would i still run rich if i put the carb setting to really lean?
    Thanks for your help. I will have to find a smaller carb.
    Aug 2005
    HI
    1,575
    You could run the 32 if you wanted to but you would need to jet down, get an aftermarket pipe, and modify the motor for the extra gas/air flow coming in. What goes in, must come out right.
    Rest in peace Rex Carlson
