The front wheel rubs when i turn hard?
fork may be bent...unless your frame is, i say forks, the wheels to close to the motor.
That a 70? Your frame is bent putting the tire too close to the motor.
what kinda 3wheeler ATC70?
yep. ATC70
check underneath you fuel tank for a bent frame...teh 70's had a tendency to bend under the tank which causes the tire /fender to rub the motor
If the frame is bent, will that be an expensive fix?
Do you know how to weld?
You'd be better off buying a new frame for it.
1985 Honda 250R
1986 Yamaha Tri-z
1984 Honda 200s
1983 Honda 200x
1982 Honda 200
No. The easiest way to fix it would be to just pull the tank and have the bent piece cut out and a new pice of pipe welded in. I would slide a smaller pipe inside the bent section and weld that in there too for extra strength. You can also get a good used frame and swap everything over. I did the frame swap on the last 70 I had because I found a used frame for $20 close enough for me to pick up.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
Do you think $260 is a fair price. It runs ok
Less than 500$ for anything that runs is ok.
Are you sure that the front tire is the correct size??
take off the fuel tank and tank a pic of the frmae under there and post it
Tionesta Trikes ATC 450R
86 250R
86 Tecate-3
83 ATC 70
85 Big Red
81 KLT 200
85 250SX
I woulda stripped it down and changed frames without even thinkin about the air pressure!![]()
YES by all means,,, try letting some air outta the tire FIRST!
but I guess it wouldn't hurt to look over the frame real good for cracks.
