Results 1 to 15 of 24
Thread: What's wrong w/ this pic?
    Columbia, MS
    11
    The front wheel rubs when i turn hard?
    Willamstown PA
    5,823
    fork may be bent...unless your frame is, i say forks, the wheels to close to the motor.
    Newfoundland
    5,280
    That a 70? Your frame is bent putting the tire too close to the motor.
    florida
    2,328
    what kinda 3wheeler ATC70?
    Columbia, MS
    11
    yep. ATC70
    florida
    2,328
    check underneath you fuel tank for a bent frame...teh 70's had a tendency to bend under the tank which causes the tire /fender to rub the motor
    Columbia, MS
    11
    If the frame is bent, will that be an expensive fix?
    Mar 2004
    NE Indiana
    497
    Do you know how to weld?
    You'd be better off buying a new frame for it.
    1985 Honda 250R
    1986 Yamaha Tri-z
    1984 Honda 200s
    1983 Honda 200x
    1982 Honda 200
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by JAYSATC View Post
    No. The easiest way to fix it would be to just pull the tank and have the bent piece cut out and a new pice of pipe welded in. I would slide a smaller pipe inside the bent section and weld that in there too for extra strength. You can also get a good used frame and swap everything over. I did the frame swap on the last 70 I had because I found a used frame for $20 close enough for me to pick up.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Columbia, MS
    11
    Do you think $260 is a fair price. It runs ok
    Less than 500$ for anything that runs is ok.
    Are you sure that the front tire is the correct size??
    florida
    2,328
    take off the fuel tank and tank a pic of the frmae under there and post it
    Kentucky
    2,294
    Was thinking the same thing, is that the stock size tire ?
    Tionesta Trikes ATC 450R
    86 250R
    86 Tecate-3
    83 ATC 70
    85 Big Red
    81 KLT 200
    85 250SX
    Aug 2002
    Jamul, CA. near San Diego
    1,605
    Quote Originally Posted by Eric250R View Post
    I was thinking stock 70 size....just about 300 lbs of air pressure in it ...........LMAO
    Pa.'s Highest City
    8,058
    sounds like I something I would do...
    I woulda stripped it down and changed frames without even thinkin about the air pressure! YES by all means,,, try letting some air outta the tire FIRST! but I guess it wouldn't hurt to look over the frame real good for cracks.
