Results 1 to 14 of 14
Thread: Honda Bearing Removal
    Oct 2006
    Ohio
    541
    What is the trick for removing the front hub bearings on my 200x? Ive been working away with no luck, seem like they are froze up or something. Any of you guys have any tricks to getting these things out?
    1997 Kawasaki Bayou 220
    2004 Yamaha YFZ450
    1985 Honda 250ES
    1982 Honda 185s For Sale
    Oct 2006
    Ohio
    541
    Anybody???
    2004 Yamaha YFZ450
    1985 Honda 250ES
    PA
    3,515
    a large and a pipe or punch....oh yeah, some large arms too...lol
    WWW.HREATV.COM
    Trouble is offline At The Back Of The Pack Arm chair racerFirst time rider
    Tony,WI
    170
    when all else fails... get a bigger !.
    Sounds like you don't have a good punch. You need a punch with a nice flat or blunt nose on it. Not a punch that is rounded. The seals get pryed out with a screwdriver but I use a 3/8 diameter punch that I grind flat on the face and it allows you to angle it inside the center tube to catch part of the inner race. You simply work it back and forth and tap them out easy but never tap on one edge so much that the bearing comes out extremely angled.
    Once a bearings inner race is even lightly tapped, it's junk....
    Lancaster, PA
    1,738
    You need to remove the bearings like Dirtcrasher said but remember the bearing are pounded out from the inside of the hub towards the outside, so you will need a longer punch. There is a spacer tube in between the bearings it should slide to one side so you and get to the bearing from the oppasite end. Does that help?
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Feb 2006
    Central Florida
    1,090
    i use a 16" 3/8 DIA die casting ejector pin... knck it from the rear
    quiet people seem intelligent
    Masshole
    2,191
    All i did was lop off a foot of 1/2 inch round stock and a big dead blow.
    Oct 2006
    Ohio
    541
    Got the arm strength, just dont want to force it out. Been down that road, just end up buying new parts. Ill work it out like you said dirtcrasher, I didnt have a good setup before, but I will definatley try that criss cross method. Makes enough sense, just wanted to check in before I got too happy. Ill try and follow up, if I dont... remind me!
    2004 Yamaha YFZ450
    1985 Honda 250ES
    Feb 2009
    Rome,NY
    1,046
    its been 2 years ... did you get them out?? lol
    May 2009
    Brampton, ontario
    686
    lol i would hope so. if it had been really hot before it blew there could be a chance he would have to cut it out. or get it pressed out.
    Looking for some smaller style tires like the r's have, just 2 back tires. pm please.
    I heard Chuck Norris gets bearings out with his weiner
    "Send Em to Chuck!!"
    greythorn3's Avatar
    greythorn3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2007
    ALASKA
    302
    chuck norris just looks at the hub and the bearings run out.
    1985 big red 250es working good. 1983 200e waiting for new crank and rod. 200x project looking needing everything.
    Oct 2006
    Ohio
    541
    Ok you old post digging whores ... I got them out, 2 years ago. I actually called chuck norris about the bearings, put the phone up to my front hub, and WALA. No, it really was that simple.
    2004 Yamaha YFZ450
    1985 Honda 250ES
