Thread: fouls on warmup
    Dec 2006
    OZ
    132
    fouls on warmup
    keep fouling plugs when warming the bike up (watercooled R). both when it idles and when i rev it. after i change the plug its fine and will not foul when running.
    do i need to turn the airscrew out some more or..?
    cheers
    sorry if this has been asked a hundred times before.
    Aug 2005
    Oregon
    490
    what ratio mix are your running in it? sounds like its just running abit rich.
    if your running a 32:1 mix, try a 40:1 mix.
    Dec 2006
    OZ
    132
    im running 40:1
    Jackson MI
    1,688
    What year Is the bike? If It's a 86, with a oval slide carb make sure the slide Is In with the cut away In the rear of the carb. Also you might have the Idle/choke knob turned out/up to far. I've found that a 42 or 45 pilot works best for my bikes, but you might need different jetting In your area. If It's a 86, I would start with setting the air screw at 1 1/2 turns out, then turn the choke/Idle adjuster until It will Idle decent, then fine tune with the air screw.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
