I've been buying the OEM Honda filter, but I hear a FRAM filter fits?
Anyone know the number for an ATC 250SX?
Thanks!
Thanks!
I don't know the number but I do know that it's the same as the 250es, 350x, and lot's of other Honda atv's.
I personally use emgo in my machines.
Hope that helps.
Howdy
fram is the cheapest POS filter made. look up any oil filter test on the internet and fram is always in last place.
Originally Posted by Howdy
Where can I find EMGO????
Thanks
I use EMGO oil filters in my 250ES;works good,no problems. Try this http://www.emgo.com/ maybe that will help.
1998 Yamaha Blaster;Wiseco and DG equiped(For sale).
1993 Yamaha Timberwolf.
1985 Honda ATC250ES(for sale).
1985 Yamaha Badger.
Dennis Kirk has them for $2.99 each. here is a link:Originally Posted by Dirtcrasher
http://www.denniskirk.com/powervendor/details/detail.asp?serverid=OffRoad&PartNo=301759
I have them also but I can't compete too well with dennis kirks $50 free shipping policy. If your not buying $50 worth of stuff from them and have to pay a shipping fee then I should be cheaper.
Here is all the machines they say this one filter fits. The 3 Wheeler models is in Bold.
Howdy
This Part Fits These Applications:
Make CC Model Year Options
Honda 200 XR200R 1984-1985
Honda 250 ATC250ES Big Red 1985-1987
Honda 250 ATC250SX 1985-1987
Honda 250 NX250 1988-1990
Honda 250 TRX250 FourTrax 1985-1987
Honda 250 TRX250X FourTrax 1987-1992
Honda 250 XL250R 1984-1987
Honda 250 XR250L 1991-1996
Honda 250 XR250R 1984-2003
Honda 300 TRX300 FourTrax 1988-2000
Honda 300 TRX300EX FourTrax 1993-2000
Honda 300 TRX300EX Sportrax 2001-2003
Honda 300 TRX300FW FourTrax 4x4 1988-1988
Honda 300 TRX300FW FourTrax 4x4 1990-2000
Honda 350 ATC350X 1985-1986
Honda 350 TRX350 FourTrax 4x4 1986-1987
Honda 350 TRX350D FourTrax Foreman 4x4 1987-1989
Honda 350 TRX350FE FourTrax Rancher ES 4x4 2000-2003
Honda 350 TRX350FM FourTrax Rancher 4x4 2000-2003
Honda 350 TRX350TE FourTrax Rancher ES 2000-2003
Honda 350 TRX350TM FourTrax Rancher 2000-2003
Honda 350 XL350R 1984-1985
Honda 350 XR350R 1983-1985
Honda 400 TRX400EX FourTrax 1999-2000
Honda 400 TRX400EX Sportrax 2001-2003
Honda 400 TRX400FW Foreman 4x4 1995-2001
Honda 400 XR400R 1996-2003
Honda 450 TRX450ES Foreman 4x4 1998-2001
Honda 450 TRX450FE Foreman ES 4x4 2002-2003
Honda 450 TRX450FM Foreman S 4x4 2002-2003
Honda 450 TRX450S Foreman S 4x4 1998-2001
Honda 500 XR500R 1983-1984
Honda 600 XL600R 1983-1987
Honda 600 XL600V Transalp 1989-1990
Honda 600 XR600R 1985-2000
Honda 650 NX650 1988-1989
Honda 650 XR650L 1993-2003
Honda 650 XR650R 2000-2003
Kawasaki 250 KL250 KLR 2000-2002
Kawasaki 250 KLX250R 1994-1996
Kawasaki 300 KLX300R 1997-2003
Kawasaki 300 KVF300 Prairie 2x4 1999-2002
Kawasaki 300 KVF300 Prairie 4x4 1999-2002
ok, i have a 1986 honda 250sx. this is the first sx i have ever owned. so im gonna ask, i may sound stupid but hey....it happenswhere is the oil filter on my bike? thanks
1986 Honda 250SX
Originally Posted by kyle
Kyle, on right side of trike, just in front of kick starter and under rear of exhaust heat shield, there's a plastic cover. 2 phillips head screws holding it on. Under that is metal cover w/3-8mm bolts holding it on. Under that is oil filter, under that is spring (don't lose it). If I were you I'd go to Honda and get 1 filter to change now and then go to denniskirk.com and order cat. Then you can order 1/2 dozen or so emgos-part #301759/$2.99 ea. (that's what I use to Howdy) and a couple other things you need/want to make the $50.00 min.
Al
TF03/HASPIN ACRES /BADLANDS SURVIVOR!!! -LIFE IS GOOD!!
'86 350x (latest addition)
'85 250sx-200x frt.end,350x bars,plastic tank,3"hub spacers,22x11x10 Fast-Trekkers/.190 Douglas Red Label alum. rims/PRM desert grab bar
'85 250sx(supertrap exhaust,chrome rims)
'87 200x(restored)-'85 200x-'84 200x
hey thanks. i have the day off work so i think i may get on changing that!
1986 Honda 250SX
WIX also makes a filter for hondas.I RAN THEM IN MY 400EX TIL IT WAS STOLEN.never had a problem with them and they are half the price of the
oem filters.you can order them at any PARTS PLUS auto store,but they
come in packs of two.
hi i am new to the forum and picked up my third trike but it's the first Ive had problems with, its a excellent condition 1985 250SX picked up for $650, it idles like a champ but loads up when throttle is applied except for when in reverse, i can wind out reverse it doesn't miss a beat, soon as i catch a forward moving gear it starts to load the engine, i have put a new plug in still same thing i let it warm up went to take it for a cruise and kept loading and wont let me open the throttle 100% about 75% runs fine once i feather the throttle and get it past the loading up, any suggestions i put SeaFoam in the gas it helped my dirt bike a 2005 CR450F that i bought sitting for about a year and the gas turned to putty i cleaned the carb then ran seafoam and now the bike runs like a raped ape, hoping for the same luck with my ATC i am open to all suggestions also i don't know if it matters the first gear is trashed it kicks and wheelies in first gear like it's missing teeth so i use 2-5
^ Welcome to 3WW
This 7 years old thread about an oil filter won't help you.
Reverse is geared so low and revs high with no load. Take that carb off, remove every single jet and needle jet holder etc etc, clean them spotless and reassemble it with an inline fuel filter. Take apart and clean the petcock too..... It's very important to remove, inspect and clean every jet with carb cleaner. I've never used Sea Foam, I hear good stuff about it; But a thorough cleaning should get you rolling on 3
Stay in this forum and put up a "new thread", then we can get going here on helping you fix it![]()
Appreciate it man
Just came from the auto parts store and wanted to share this information. I wasn't sure where to put it, so I'll post it here. The Fram oil filter to use with a 1987 Honda Big Red 250es is CH6015. The Autolite spark filter is 4164.
