I just got my engine put back together, after putting a new timing chain. I cranked it up, I noticed the pull start was a little tighter than usual, but no big difference. It started up on the first pull, was beggining to idle, then I heard a squeak like when you tighten a screw as much as you can and the engine just shut off. Now I can't even pull on the pull start because it is so tight. what could it be? please help. (I have a 200s engine by the way) Thanks
