Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: engine problems
    Aug 2007
    Gunn,Alberta
    31
    Question engine problems
    hi im new to this site but i think its really cool from the pics ive seen. ive got an old 1983 Yamaha 225DX and im having engine problems. it turns over theres, a spark, but it does not fire. any input would be greatly appreciated as i love my trike more than any other offroad vehicle ive had before
    Feb 2006
    Central Florida
    1,090
    if there is a spark, there is fire.
    were you saying there is spark but the engine is not catching at all?
    quiet people seem intelligent
    Aug 2007
    Gunn,Alberta
    31
    yes sorry thats what i meant.
    there is spark but it will not start. ive tried using liquid fire through the car but it still wont start. i thought id ask around but i am going to buy a service manual one of these days i just dont know when.
    Oregon
    2,471
    Adjust the Valves , Clean the Carb or Over haul it , Buy new Spark plugs !
    Should be fine after this ....
    Jul 2006
    western ny
    3,366
    does it have fresh gas ? put some gas down the head and try to fire it like that. if it fires it is more than likely carb issues. is the spark blue ? as said before you may need to adjust the valves too. if you need specs let me know. ill get them for ya.
    GIT IT RAAAGGGGG !!!!
    Aug 2007
    Gunn,Alberta
    31
    ive cleaned the carb already and the spark is blue but it is very small so i need to get a new plug anyway. by putting fresh gas down the head do you mean directly where the spark plug comes out? and how do i adjust the valves? if you dont mind those specs would be great thanks
    Feb 2006
    Central Florida
    1,090
    are you sure you are getting fuel? loosen the drain screw in the float bowl, if not, and see if fuel comes out.
    Jul 2006
    western ny
    3,366
    yes put the gas where the spark plug goes. not allot only about 2 table spoons or so. ok the adjustments are intake: 0.002-0.004 and the exhaust: 0.0043-0.006
    as for adjusting them im not a huge help. but if they are like honda you need to take off the valve covers. make sure the engine is tdc (top dead center) and use feeler gages to check the gap. if they need adjusting you need to losen a little nut on the rocker and adjust as needed. but thats how my honda gets adjusted and yammie may be a little diff.
    Aug 2007
    Gunn,Alberta
    31
    oh ok thanx. im gonna go try that next. i was wondering where i could buy feeler gauges ive looked for them in some automotive stores but i cant find any. do i need to buy them at a yamaha dealer or something like that?
    Jul 2006
    western ny
    3,366
    no any car quest, auto zone, napa should have them. if you cant find them ask a serviceman behind the counter. they will point you in the rite direction. ypu better get your self a manual asap. i know they arnt the cheapst thing in the world but they help allot.
    Aug 2007
    Gunn,Alberta
    31
    well it didnt work with the fuel in the head. but i tried it with liquid fire on the spark plug and it started for a second and then shut off. i dont think its getting any fuel and the carburater leaks at the bottom and i cant tighten the screw anymore thats there
    Jul 2006
    western ny
    3,366
    take the carb apart and clean it real good. get a pin and poke it threw all the tiny holes in the jets.
    as for it not firing on the fuel in the head. sounds like a weak spark. make sure your grounds are good and put a new plug in it. you should have a solid sharp blue spark. if it helps any i use split fire plugs.
    Aug 2007
    Gunn,Alberta
    31
    well i cant even loosen it cuz it leaks on its own so i dont know what to do there
    Feb 2006
    Central Florida
    1,090
    what is liquid fire? is it some form of flammable chemical that you are putting on the plug? i have never heard of it.
    if your carb is leaking you don't want to get it running anyways. trust me- I burnt a fresh build to the ground one day
    the carb leaks at the bottom? be specific. float bowl? if the threads are stripped you may be able to run a small bolt with a nut on the back side to tighten it up
    Jul 2006
    western ny
    3,366
    ok where you from ? if your in the us send it to me ill do it for free if you want. just pay shipping both ways. what machine is it on ?
