Page 3 of 3 FirstFirst 1 2 3
Results 31 to 35 of 35
Thread: 250R Aluminum Swingarm Extension Project (finished)
  1. #31
    Jan 2008
    NW Indiana
    92
    Good job on the swinger. I want to know how different the ride is with the extension. I want to add some inches to mine to keep the front end down when blazing the dunes. But I want to know if it's really worth the trouble.
  2. #32
    Las Vegas, NV.
    2,531
    Quote Originally Posted by FPMXer View Post
    Thanks. I'll get you a ride report as soon as I get to ride. Since I finished the swingarm, I've only been on 1 ride, and that only lasted 12-15 minutes until my motor seized, due to a failed waterpump. For some reason, no waterpump = no coolant flow, which = no motor worky. I'm now in the process of completely rebuilding the entire bottom end, new crank/rod, seals & bearings.
  3. #33
    Jan 2008
    NW Indiana
    92
    That sucks to hear.
    Bikes I currently own.....
    84' KXT 250
    01' Honda CR500
    98' Arctic cat ZRT800
    82' Honda atc70
  4. #34
    Las Vegas, NV.
    2,531
    While I'm waiting on some parts to complete the engine rebuild, I began searching for a longer skidplate to fit my lengthened swingarm. I called all of the aftermarket skidplate manufacturers, whose work & products I like, and none of them offered longer skidplates for lengthened swingarms, nor are they interested in making 1. So, I decided to get a new skidplate and lengthen it myself. I settled on a unit from XFR (www.xfrproatv.com) as they offer an excellent product for a decent price.
    Once I was back into fabrication mode, I began to cut up a perfectly good, brand new plate, that I'd just shelled out $72 for. I completely forgot about taking pics of the whole process, but I think I can explain it fairly clearly. I cut the skidplate into 2 pieces, front & rear. The front piece contained the forward mounting tabs & the shock linkage protection. The rear piece contained the rear mounts & the sprocket/chain & disc brake guards. I cut out a 2" wide piece of 3/16" thick 6061 plate aluminum, as the spacer, for in between the front & rear skidplate halves, clamped everything in place, and then had it all welded back together. I also bent a piece of aluminum plate into a "U" shape, and had that welded to the front to better protect the lower shock-to-frame linkage.
    Attached Thumbnails Attached Thumbnails SkidplateT.JPG   SkidplateB.JPG   SkidplateL.JPG   SkidplateR.JPG
  5. #35
    Las Vegas, NV.
    2,531
    I finally got around to installing the new skidplate & Pro-Link stickers. Now my bike is really looking like the '88 ATC250R that Honda never built.
    Attached Thumbnails Attached Thumbnails ProLeft.JPG   ProBack.JPG   ProRight.JPG
