Results 1 to 9 of 9
Thread: dont know about battery
    newfoundland
    21
    i gottta 200e and its my secound trike my first one never had a battery and im not sure if this one does or not i dont see it but dont you need one for your headlight to work? or maybe not? if you could tell me where to look thast would help alot thanks alot guys. can you hook up electric start on a 200e thats the whole reason im askin about this
    florida
    2,328
    the 200E has elec. start...the battery is under the seat.
    newfoundland
    21
    i dont see no battery under the seat i just took it off and all thats there is the airbox and anouther little plastic box...unless the little plastic one is the battery ...but it dont look like it
    florida
    2,328
    there may be no battery in it...
    Apr 2005
    Elrod, IN (near Milan)
    114
    Battery location
    Take the seat off. Between the airbox and axle you will find the battery. If there is an empty void there that is rectangular in shape, that's where your battery goes. Be sure to measure the opening and buy the right size battery. Buy the biggest one that will fit the void. A dead battery will cause a very dim headlight, but I'm not sure if no battery will cause no headlight. When I bought my '85 Big Red, it had no battery, but the headlight still worked. I've heard that running with no battery is no good on the charging system, but the guy I bought mine from said he ran it for many years without a battery and it still charges. Check your headlight bulb. If good, check for current to the headlight and go from there.
    I'M GETTING TOO OLD. IT TAKES ME AN HOUR AND A HALF JUST TO WATCH 60 MINUTES.
    '85 Big Red 250es (Beer truck)
    '85 350x
    '85 250r
    '84 ATC70
    '01 Yamaha Warrior 350
    '05 Honda Recon 250
    Always looking for more!!!
    '05, '06, '07 TF survivor. Looking forward to '08!
    newfoundland
    21
    no its really really dim
    Missouri
    99
    I suggest an agm or gel battery. they are sealed and last alot longer, plus they cost about the same as regular one.
    http://www.batterymart.com/
    Proud owner of a "cornfed" polaris 500 scrambler. . . 4X4
    Coming soon Ninja/mojave/dune buggy, three wheeler
    Visit www.tecateconnection.com for tecate info and to find out whats going on in the tecate world!
    Apr 2005
    114
    Battery
    A friend of mine has a 200e with a bad battery. He has a very dim headlight. A flashlight taped to the bars would do much better than his headlight. So yes, if you had a good battery in yours, your headlight be much brighter. Madman is right, look for a sealed gel cell battery. If you buy the cheapos, it may get you by for a year if you're lucky. Good luck.
    '85 350x
    '85 250r
    '84 ATC70
    '05 Honda Recon 250
    Nov 2006
    Tulare, California
    719
    Shanepaul, I would PM fellow board member named damnit!. Ask him if you can download a copy of his pdf shop manual for your bike. I am sure he will be glad to help.
    Current Bike:
    1985 Honda 350X
    Bikes owned:
    1984 Honda 200X
    1982 Honda 250R
    1985 Honda 350X x3
    1985 Honda 250R x2
    1985 Honda 500X
