Results 1 to 15 of 30
Thread: Some new flat tracker pics. LRD 270 motor and LRD adustable ATC pipe installed
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Well I first started assembling this 270cc flat track motor back in November of last year. I ran into several problem after I first ran it. They are detailed in this thread: http://3wheelerworldforums.com/showthread.php?t=60554 After repairing the sleeve chipping incident The project ultimately culminated in the fact that there was an area of the left center case previously repaired that had been warped, and the center case gasket kept getting sucked into teh crankcase allowing the trans fluid to be burnt. I've spent the last few months procrastinating, dealing with that and also having to put up with an improperly machined Hot rods crankshaft that left the main bearing journals .003 larger then the ID of the bearings. I ended up re-machining it to the proper tolerances myself. The crank was always such a *Edited**Edited**Edited**Edited**Edited* to get in and out of the bearings or out of the cases. I figured it out after I measured it and see how much they were out.
    At trikefest, I also scored a very, very rare LRD adjustable ATC pipe to match the porting on this cylinder from Willie (86waterpumper) I had to trade a whole dirt bike for it, but I got it Its currently adjusted for low end with it as as long as it gets. You can adjust those bolts and make it shorter for more top end power. It fits kinda crappy, you have to take one of the side motor mount bolts out to keep it from rubbing and to even get it mounted on the exhaust flange. Everything else seemed to line up pretty nicely though.
    I spent today dialing in the carb, which I think I have pretty close (I seem to be getting much better at carb work, I can get one pretty close in just a few hours now). It runs AWESOME. I went from a 152 main to a 185 and I'm right on the bleeding edge of being to lean, I'm going to watch it tomorrow and might bump it up to a 188 or 190 if it doesnt get any darker. The lowend snap this thing has now with the engine build and that pipe combination is like a 4 stroke. You can be idling in first and go to a 1/4 throttle and it snaps your neck. You open it up more then that and its just freakin nuts. Waaaaay faster then it was with the stock motor I had on it at TF. We have a race tomorrow, interested to see how it ends up doing.
    Live Oak, FL
    15,069
    Last 3 pics
    Jul 2006
    western ny
    3,366
    nice ride billy. that thing looks killer. let us know how she does for ya.
    GIT IT RAAAGGGGG !!!!
    Dec 2006
    W. PA
    463
    sweet pipe!
    1984 250r
    heap of 200x
    POS motorcraft?
    Quote Originally Posted by JAGSFOLIFE
    THOSE F^@&ERS ARE DEATH TRAPS, BUT SO BAD @$$...
    Quote Originally Posted by yamaha gp
    trikes... DANGEROUS MOTHER F***S. BUDDY LOST HALF HIS SPLEEN AND A LIVER BECAUSE OF ONE OF THEN. HAHAH
    Quote Originally Posted by smackdab
    We decided those cute little 90 and 110 Honda 3 wheelers were what we all needed. Although our experience with those little SOB's is a story for another day, I will tell you that the Caro Community Hospital got new waiting room furniture due to those cute little devils.
    Sep 2006
    Northwest Indiana
    1,893
    An adjustable R pipe? Now that's trick! Yet another item i never knew existed. Good luck with the race.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Smile
    Looking good Billy!!!!!!!
    May 2005
    Australia
    1,047
    I spy a "JMC Racing" aka Greenhuman decal on the fender Billy,thats an Australian touch mate good to see , just need some Vegemite before the races and you will be unstopable.
    Aussie
    Keeping 3 Wheelers Alive Downunder !
    na
    5,702
    Faster than though one at trikefest
    That other one flew as it was.
    Keep that engine
    Looks good.You should clean house with that thing.
    From my experience with Banshee's that run wide open,I would really get away from being on the lean side on that main jet.Better fatten it up for WOT for extended romps on those flat tracks.
    Seen alot of shee pistons with holes in them from guys runnin Wot down the road and then BAMMM.bye bye motor.
    HAve fun with it and let us know how she runs.
    Proudly NOT a member of
    "Team on the Teat"
    Live Oak, FL
    15,069
    Well I only got 2 practices and a heat in before it started raining last night at the race, but it seemed to run very very well. I'm still super impressed with that LRD pipe, I lost no top end pull and it has a low end snap like a 4 stroke now. I plan on adjusting it all the way short for topend pull and see how it performs then. For all the people that told me that cylinder with the chunk of sleeve missing that I beveled out would never run, its done pretty well so far
    Nov 2006
    Tulare, California
    719
    That trike is looking great Billy. Is that a Duncan Racing foot shift lever? One more question, have you ever used an FMF Turbine Core silencer? If so how would you compare it to your Power Core you are using right now?
    Current Bike:
    1985 Honda 350X
    Bikes owned:
    1984 Honda 200X
    1982 Honda 250R
    1985 Honda 350X x3
    1985 Honda 250R x2
    1985 Honda 500X
    Live Oak, FL
    15,069
    The shifter is a Pro-Design power shifter. I haven't ever ran the turbine core silencer, didn't know that one was available for the R? I'm not sure how much of a difference there really would be. I know this particular one is actually pretty loud, although I haven't repacked it yet.
    Nov 2006
    Tulare, California
    719
    Yeah I got a Turbine Core silencer with a built-in sparky for my 85 R. Just repacked it a few months ago. The sparky might be ad-on but its an FMF. I was wondering because I want to put a high performance expansion chamber like you guys with the flat trackers, but I did not know if they would mix well with the FMF silencer.
    Current Bike:
    1985 Honda 350X
    Bikes owned:
    1984 Honda 200X
    1982 Honda 250R
    1985 Honda 350X x3
    1985 Honda 250R x2
    1985 Honda 500X
    Nov 2006
    Florida
    1,663
    I got a Bill's pipe and I use a FMF silencer on my trike, runs pretty good too
    Nov 2006
    Tulare, California
    719
    Quote Originally Posted by oldsking86 View Post
    Cool. I think I got my sights set on a PT high rev.
    Current Bike:
    1985 Honda 350X
    Bikes owned:
    1984 Honda 200X
    1982 Honda 250R
    1985 Honda 350X x3
    1985 Honda 250R x2
    1985 Honda 500X
    Looks sweeeeeeet, clean up that excess high temp red off of that lovely pipe will ya!! LOL....
