I found out i have no spark. It ran before the rebuild so i know its the wiring somewheres. How many grouns is there supposed to be? im confused on why there is no spark. reply asap
Auto-X-4-sale
pull your wiring shematic from the home page and see what you missed.
quiet people seem intelligent
try cleaning all the connections on the coil, cdi and battery(if installed). that is all i had to do to get mine sparking.
I have one ground and it comes from a very tiny black box i dk what it is. I have no idea y there is no spark only one ground and i have it hooked up and i didnt unplug nething so what else could make it not spark? timing?
Auto-X-4-sale
it is a signal - trace it back to origination. test it and see where it drops. what are you working on? did you rebuild it?
is this related?:
can someone help me i am getting no spark on my 185S/200X frame. I dk if i ra my grouns and stuff rite. Is there 2 cause i wired 2 of them. Post pics of what the wiring is supposed to look like, explain just help me plz im stumped
Be patient and check and re-check everything with the wiring diagrams, clean your grounds up with sandpaper and make sure you didnt break any wires during the removal-instalation. Oh and try changing your plug, is it the old one from when that motor was smoking, may be fouled.
all the wires are good i am gunna get a new plug tomorrow. Timing wouldnt make it not spark rite? its a 185S motor 1982. Do i have to mess with the cdi that connects to the cam since i took it all apart?? like time it with the cam?
Auto-X-4-sale
BUY A MANUAL
How many times must I say this....
Rest in peace Rex Carlson
rust on the pulser or flywheel? pull the cover off the pulser on the side of the head and crank it over to ake sure its turning.
post some pictures.. alot of us would know if we could look at it
timed or not - if everything else works it will spark. its just a mater of when it sparks = time. good idea about the rust eric...
manuals are good... you can download one from
http://www.3wheelerworldforums.com/s...ad.php?t=56218
did you see if the coil wire to the plug was good ? meaning is it in the coil tight? also is the part that goes to the plug tight ? is there any cracks in the wire ? as said before we need pictures.
down to parts because i no longer have a place to ride trikes.![]()
GIT IT RAAAGGGGG !!!!
Online manuals are OK but a real manual(like a booK) does wonders when you are out in the garage and you can just flip to the page and BAM there you go. Manuals cost so little. Just buy one and all your troubles will either go away, or you will be able to deduct a final solution to your problem...
Where ya at brownie
I had the same problem with a Big Red and I finally found the problem. The wire in the kill switch got crimped and wore through. You might want to check this.
