Results 1 to 8 of 8
Thread: Need ATC 70 help
    Apr 2005
    Elrod, IN (near Milan)
    114
    Need ATC 70 help
    I just came across a 1984 ATC 70. It was a barn find. I got it very cheap. Cosmetically, it's in good shape. I just ordered a new front fender, rear plastic is very nice w/decals intact. Chrome is a bit rusty, tank rusty inside, seat good. I was just messing around with it and found out it does not have a spark (with a NEW plug). Are the points located behind the flywheel on these? I thought they were on the top end where the CDI pulse generators are located on the newer models. Don't know much about the 70s. I'm not sure what to do here, sell it as-is or try to get it running. It needs tires due to sitting for a decade. If I knew all it needed was points and a carb rebuild I would definitely do it, but it could be the coil, stator, wiring, or anything after sitting that long. I don't want to stick $200 in it and get $250 out of it. Any ideas? I know some of you are probably thinking "buy a book", but again, I'm not sure if I'm going to get it running or just unload it as-is. It doesn't take long to exceed the value of these little bikes. Thanks for your help.
    I'M GETTING TOO OLD. IT TAKES ME AN HOUR AND A HALF JUST TO WATCH 60 MINUTES.
    '85 Big Red 250es (Beer truck)
    '85 350x
    '85 250r
    '84 ATC70
    '01 Yamaha Warrior 350
    '05 Honda Recon 250
    Always looking for more!!!
    '05, '06, '07 TF survivor. Looking forward to '08!
    Oregon
    2,471
    Dude once you get it running - you'll be in love !
    These 70's are awesome
    Post Some Pictures ??
    Lancaster, PA
    1,738
    Welcome to the insane worlds of 70s!!! And once you change the points under the flywheel you will never go back. lol
    No really the most common issue is the points go out and they are under the flywheel.
    Here is a manual
    http://www.glamisdunes.com/invision/...howtopic=92462
    and a good forum site on ATC70s
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Jul 2006
    Get it running Bob and bring it to TF 08 and I'll buy it from you for the camp site discount. Tell Ronda I said hi. Lopes
    Apr 2005
    114
    Thanks Blue27!
    Damn, that's the info I was looking for Blue27! Thanks a mil. Now I hope I have a flywheel puller for it. I have 3 pullers, but you know how that goes. Guess I'll be ordering a set of points.
    As for you Lopes, if I have enough beer at TF'08 camp, we WILL negotiate! Good to hear from you again! Bring PLENTY of money (among other things, hehehe).
    '85 350x
    '85 250r
    '84 ATC70
    '05 Honda Recon 250
    Des Moines, IA
    1,303
    Hey, speaking of removing flywheels, have any of you guys had problems removing the flywheel on one of these? I decided to do the points on my 70 and I couldn't get the flywheel out of the housing! It came off the shaft fine, but as it gets halfway out of the opening, it gets stuck! What gives?
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    Oregon
    2,471
    Soak it with PB BLaster for a Day !
    Lancaster, PA
    1,738
    Pull the side cover off, the cover that the pullstart bolts to , you will have to remove the chainguard, just unbolt it enough that the side cover comes off. See if that helps if not post a pic of what you got.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    and many more!!!
    Blue Line Graphics
