Does anyone know where I can find an old polaris star "free air" wiring diagram 1976-1979 I think on the web?
Hey bro, check out vintagesleds.com. post in the classifieds. also see nhsnowmobilemuseum.com. Again post in the classified sections. Someone will be able to help you there. I do alot of vintage sled stuff. But not polaris......... Sorry bro hope that helps
what model ? i have so many i can scan. i just have to find them. i had a 79 polaris gemini 244 lol it was slow but a blast. its all i know is vintage sleds.
down to parts because i no longer have a place to ride trikes.![]()
GIT IT RAAAGGGGG !!!!
Lol to tell you the truth, I don't know what model the Polaris motor is.All I know is that itr says "polaris star motor"on the recoil and its a "free air" with dual carbs.I couldn't find the displacement of the motor.Oh yeah and there are three bolts for the cylinder head.I'd say it's either a 250 or a 340.It could be out of a colt or tx or an apollo. I have 29 sleds but no polaris ones.
sounds like a colt ss to me. there should be numbers stamped somewhere on the cylinders. they dont tell the cc but i can use them to look up the engine model.
I found a set of numbers near the bottom of the right cylinder by the recoil.Here hey are...EC34PM-04.
ok i will dig out the book asap
Its not a f/c its a free air because there is no fan shroud and the fins a spaced out more than a fan cooled fins are.
http://images.google.ca/imgres?imgur...3D10%26hl%3Den
I'm pretty sure this is the motor.
hmmm, I wonder if someone put the free air cylinders on a different base then, I'm just going off what the numbers matched in my service manual. Does it look like there were ever part of a fan casing on the crank case?
1984 250r
heap of 200x
POS motorcraft?
Originally Posted by JAGSFOLIFE
Originally Posted by yamaha gp
Originally Posted by smackdab
nope
Did you see the link i'm pretty sure thats the sled.Has same carb airfilters,dualcarbs,free air,4 bolts for head cylinder,clutch looks similar except mine is silver,single y pipe exhaust manifold.
i had a 73 colt 294ss that was exactly like what you are discribing but as toocheap said those numbers are off a 340 fan cooled polaris. unless polaris used the same cyl. on diff. model sleds. hard to say without seeing it.
How can I attach a pic so it wold be on my sig
Oh i just found another set of numbers under the exhaust manifold.404825.
