Results 16 to 30 of 45
Thread: swinger project pics
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    I think we can get that thing held together pretty well Louis. I have a lot of 1/4 plate here I will use as additional bracing and support on the bottom and also the sides if need be.
    Maryland
    3,077
    I'm confident too. The first one my machinist buddy did is super strong and it really doesn't look like anything special. I think the jig is going to be the hardest part.
    Newfoundland
    5,280
    Jigs are easy enough. When the fitment is good it looks like you will have more then enough weld to not need additional plate.
    Going to look nice I should add, not to put too much pressure on ya Billy.
    Las Vegas, NV.
    2,522
    Quote Originally Posted by Louis Mielke View Post
    Excellent! I'm very glad to hear that. How hard was it to change those out. Did you bother to re-spring yours?
    It was easy. Not as easy as regular forks, but nothing complex. It was just a few more parts & little bit more involved. Just follow the steps in the WP manual, which I or Billy can email to you if necessary. I did respring mine, but I can't remember what weight I went with right now. I'd have to look at the box to see what I got.
    Also how do you have your clickers adjusted? I'm gonna get these things right if it kills me.
    I think I have both the rebound & compression adjusted to the center of the range of clicks. Just play around with it and see how it feels. You'll find the sweet spot eventually, while having a lot of fun riding and testing!
    3leggeddog's Avatar
    Nov 2004
    remember those bushings go bad aswell,then the fork puts pressure on the seal causing it to wear out premature.do a full rebuild on them,and the good seals.also are you putting in too much oil?if they compress so far,and the oil has no wear to go,the seal is the weakest link.
    i can provide some plate 6061-1/4 to 1/2 stock.let me know,i can shear it off,put little bends in it,whatever you guys need.lmk!
    Maryland
    3,077
    The moto pro suspension place was SUPPOSED to check all the part for wear and service whatever the forks needed. Who knows if he actually did it or not so when I get them tore down I'll inspect everything carefully and order parts accordingly.
    Thanks for the help brandon, if we need the plate we'll shoot you a message.
    Maryland
    3,077
    Billy, here's an update. i think I'm ready to ship it to you unless you have any objections. Let me know man.
    The jig was a pain and the stick welding isn't amazing or anything. it is held pretty securley. You man want to clamp it down to a table or something though,. This is really the best I could do. I suck I know.
    Here's a comparison picture for giggles, the stock 400ex, versuses the new 500 arm, and hopefully once your done welding I can line all three swingarms up.
    Lemme know man and I can ship tomarrow if it suits.
    Live Oak, FL
    15,069
    Send it this way mang, we'll make it work!
    Live Oak, FL
    15,069
    Louis I started working on your swinger this afternoon. I've got it joined pretty fair on both the top and the bottom. Most of the joints are gonna get atleast triple pass welds because of the thicknesses involved. The gaps in the joints are a little bit of a concern to me but I believe with the depth I'm beveling things I should be getting feel penetration with a little bit of bleed through to the inside.
    Maryland
    3,077
    Billy you are awesome.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,246
    FANTASTIC JOB GUYS!!! can't wait to see it installed!!!!
    Live Oak, FL
    15,069
    Progress thus far: I'm going to start out with some before pictures. I ground down all the gaps, the thicker areas I ground out a lot, and I will double pass them to fill them completely back in. That would mainly be on the sections on the top and bottom rails. The sides aren't as thick and don't need to be double passed if you V them down good.
    Pic#1: The inside portion of the swingarm right behind the shock mount, Right hand corner, V'ed out and ready for some weld.
    Pic#2: Same part as above, but the left hand corner instead. Couldn't V out quite the same as the right because the material was not as thick as it was on the right side.
    Pic#3: One of the side, and edge joints V'ed out. Not sure if this was the left or the right side. As I mentioned before, you can see the sides themselves are not that thick, but the corners and the top and bottom portions of the tubing area.
    Pic#4: Another shot of that one V'ed out corner behind the shock mount.
    Attached Thumbnails Attached Thumbnails P1010082 (Large).JPG   P1010080 (Large).JPG   P1010077 (Large).JPG   P1010069 (Large).JPG
    Live Oak, FL
    15,069
    OK, now onto some of the weld pics:
    Pic#1: Corner gussets in the corners behind the shock mount, and also the base/bottom pass on the right hand side tubing joint on the top side.
    Pic#2. Both left and right corner gussets behind the shock mount, and also both of the top side base/bottom passes for both sides of the tubing joints.
    Pic#3: Closeup of the left hand corner gusset behind the shock mount. Thats pure weld, pass after pass after pass of it.
    Pic#4: Same as the above, but the right hand corner.
    Pic#5: Base/Bottom pass for the top joint on the left hand side. Some of these beads don't look real pretty but the gaps I was having to fill in were quite impressive, I I had to kind of keep jumping around to keep the pool from "falling" in.
    Pic#6: Single pass on the side of the right hand sides joint, and the base pass for the top of the tubing in that area. You can see how far down in the weld is when you look at the one right under that shock mount eyelet.
    Attached Thumbnails Attached Thumbnails P1010113 (Large).JPG   P1010114 (Large).JPG   P1010110 (Large).JPG   P1010109 (Large).JPG   P1010094 (Large).JPG   P1010148 (Large).JPG
    Mar 2004
    North Central Ohio!!
    2,712
    Hey Louis, I just wanted to add a note to this thread. After RE-reading the whole thing I noticed you shortened the swinger around 5". I would rethink making a new subframe until that shorter swinger is on there. Not only will it lower your seat height by the 2.5" you want, but it will probably stiffen your rear shock up a ton as well. That should mean you'll end up running less spring tension, which should also allow you to drop the rear some.
  15. #30
    Live Oak, FL
    15,069
    OK, Heres the final ones for now.
    Pic#1: Just another close up of the on joint.
    Pic#2: Another view of the gussets behind the shock mount and also the joint that runs on the top next to it.
    Pic#3: Some bottom welds and a good view of Louis' jig he made to send the swinger to me.
    Pic#4: Final one, just a good over all shot.
    Attached Thumbnails Attached Thumbnails P1010135 (Large).JPG   P1010112 (Large).JPG   P1010088 (Large).JPG   P1010154 (Large).JPG
