Ok here is the issue I'm having with my 225. Just put new oem rings into a excellent std bore cylinder. had valves ,seets done too. New valve seals after checking valve guides and they too were still within specs. Started it up, runs great, no smoke until after it runs for 10 minutes? It won't smoke at all when cold and it is white smoke. I've put used rings and pistons into a slightly worn cylinder and have it run and not smoke period so I can't understand what Ive done wrong or overlooked.
Anybody else run into this same problem?![]()
