Runs great as long as I'm not trying to run full out or even close...
It stalls ..let it sit a couple of minutes starts right up?
plug and gas have been replaced.. I'm thinking carb but what specifically?
any help/suggestions greatly apprciated
Is the float set too low??
I would clean out the carb and then go from there also clean out the petcock while your at it.
Justin
04 Trx 450r
85 Atc 350x
86 Trx 200sx
00 Xr 400R
85 Atc 70
98 Toyota Tacoma 4x4 xtra cab
99 400ex, 97 xr400, 85 Atc 110, 86 Atc 200x, 85 Atc 350X, 87 Trx 250X, 86 Atc 250R (mint), 78 Atc 90 all sold
...friends gotta 86 250 bigred, does the same thing :?
-86 Polaris Scrambler 250r/es - sold
-84 200es Big Red
-92 Ski-Doo Formula Plus 583 -88 Safari 377 -68 Super Olimpique 299
-87 Jeep XJ 5" lift/many other mods-sold
-89 F-150 4" Lift/33s
-90 Acura Integra - '83 Mustang 5.0 convertible (the new project)
Ask me about custom cut decals!
I have an '85 200M and it will run WFO all day long if tried to. I have run it wide open a lot during hunting trips to Lake Abitibi in northern Ontario.
Check to see if you have sufficient fuel flow from tank to carb. If you pull off the fuel line and open the petcock on the tank, you should see a steady stream of gas. If it just dribbles out, something is clogged in the petcock. Also check the fuel hose to make sure it is not clogged or kinked. If your machine will run wide open for even a short time then it is unlikely to be a carb problem other than a very low float level, but I think that would create other driveability problems as well. Verify sufficient fuel flow first. Good Luck, GlennMc.
try a different gas cap if the petcock and fuel line are good.
