Got a non running 3 wheeler on a trade, told it needed rings. Pulled it apart and this is what i found.
yes that is bad!!!
1985 Tiger 250LC
1985 Tiger 200LC
1985 ATC 350X
1985 ATC 200x
1973 ATC 70 (resto project)
and many more!!!
Blue Line Graphics
hmmmm yea thats really bad. what kinda trike is it ? if its a 185s or 200s i have extra heads and rocker covers ill sell ya. but im fresh out of cams.
welcome to 3ww by the way
down to parts because i no longer have a place to ride trikes.![]()
GIT IT RAAAGGGGG !!!!
damn, yes that is bad.
oh and![]()
Its a 200x. i just ordered the new parts $200 woohoo, probably got ripped but want it ready for silver lake one September 16th.
i could have gotten you a brand new o.e.m cam for 60 and ebay or someone on here could have gotten you a head and rocker cover allot cheaper.
but i guess 200 isnt all too bad.
ooooo not too bad at all. who you go threw.
ive never used em either. but ive herd they are good.
nope not bad at all... id run it for another couple of years...
lol sorry i had to be a smart *Edited**Edited**Edited**Edited**Edited*
wow! Look how warped that cam lobe is!!
Rest in peace Rex Carlson
Ok, a simple fix, but what's caused it? Why's the rocker broken? Did it sieze on the shaft? Did the valve drop? What is going on inside the cylinder?? One last thing, never use mismatched parts. Use all new or a matched set of used cam and rockers. Mismatching used surfaces will pretty much guarrantee another galling problem right away.
you might want to get the other rocker so you have a fresh surface rubbing on that new cam so you dont tear it up.
also check the oil pump ....make shure its working 100%
edit.... after looking at those pics again i would split the cases and clean that motor out before running it....all that metal went someware
WWW.HREATV.COM
