Results 1 to 3 of 3
Thread: honda atc 70 HELP!!!!!!
    OHIO
    2,857
    need help? What year pull start recoils are interchangeable on atc 70? Got an 85 motor and a cover off ebay but pull start innard are too deep and hit cracnk bolt and leave gap between recoil and chan side cover? Got the cover gasket off bikebandit OEM??? Are the gaskets very thick for these? Whats the problem? also, is it worth rebuilding carb on it for 25-30.00 or buy new for 50.00?? Help in Ohio???
    Lancaster, PA
    1,738
    73-74 starters are different then the 78-85s. What tear 70 do you have? pics? depending on how bad the carb is it can be rebuilt.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    DarkestGKnight's Avatar
    DarkestGKnight is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Babylon
    448
    y waste a carb just spray it down with carb cleaner or soak it and just buy the rebuilt kit saves u 20 bucks.
    1982 yamaha rx50.
    2001 murray minibike with 5hp.
    fully modded goped.
    250cc 4 stroke shifter kart in the process.
