Results 1 to 2 of 2
Thread: t3 rear carrier question....bgm!!!!
    Oct 2005
    saratoga, ny
    2,819
    was wondering if someone can tell me if the 85 carrier will fit on the 86 swinger. bgm i know you did the swap, does it work? i am gonna be going to get another 85 t3 in september, and it has an extended axle on it, seeing how im more then likely gonna be using the one im getting to get the one i already have running, and it already has a 50inch rear end on it, i was thinking of using the extended axle on the 86 to widen its rear end seeing is how its so narrow right now.
    Newfoundland
    5,280
    The 85 carrier bolts right on. Use the 85's rotor and the 85's rear caliper. Easy swap.
