Results 1 to 15 of 24
Thread: Starting problems
    Aug 2007
    PA
    16
    Exclamation Starting problems
    Ok guys I just got my trike back together and now it won't start
    I sprayed starter fluid in the air intake and that didnt do it. I have good compression and spark anyone have any other ideas I should try.
    Jul 2006
    western ny
    3,366
    timming could be off. if you have compression and sprayed starting fluid in there it should have fires. recheck the timing. remember just because you have spark dont mean you have spark at the rite time.
    GIT IT RAAAGGGGG !!!!
    Aug 2007
    PA
    16
    How do I check the timing. Working on it isn't the same as working on my car.
    Jul 2006
    western ny
    3,366
    lol ok what model trike you got ?
    Aug 2007
    PA
    16
    Its an 84 ytm 125L when I bought it the motor was torn down I put it together but before I put the piston in my son decided to yank on the pull starter
    springville, PA
    6,185
    Do you have fuel to the cylinders? Probably a plugged pilot jet
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Jul 2006
    western ny
    3,366
    Quote Originally Posted by Ltown3wheelin View Post
    dam man sorry. i dont know jack about yammie.
    Aug 2007
    PA
    16
    Quote Originally Posted by 250sxwheeliepop View Post
    Nope It was bone dry and when I took the head off tonite I had fuel in the cylinder.
    Aug 2007
    PA
    16
    The guy who sold it to me was only gonna use it as a parts trike I couldn't let that happen. I'm looking for a honda now, but cash flow is low.
    springville, PA
    6,185
    It cant be timing since its a 2 stroke. If you have fuel, spark, and compression the only thing I can tell you is you flooded it out
    Nate
    R.I.P HRR
    Aug 2007
    PA
    16
    Alright thanks man I'll try again in the morning.
    Jul 2006
    western ny
    3,366
    lol told ya i didnt know anything about yammie. hell i didn even know what machine he was talking about. oooo well. take it away yammie guys.
    sorry for wasting your time.
    Aug 2007
    Moab, UT
    1,807
    OK OK, I know I'm a noob here, however I am also a freelance mechanic and I can't help but state the obvious. For an internal combustion engine to run you need fuel, spark, and finally oxygen. How's the air filter on that thing? Have you tried starting it without it. Because man everything starts on ether unless you drown the plug with it in which case there won't be a spark cause the current will just travel through the soaked electrode. If it still won't start with the air filter off and just a couple huffs of ether you may have weak spark in which case the compression in the cylinder is actually suppressing your spark so as not to achieve combustion. There's alot of variables here and I need more specifics to really know which route to take in diagnosing this. If your compression is too low she won't pop either.
    Aug 2007
    PA
    16
    Quote Originally Posted by NINJA View Post
    Tried without the air filter it still didn't work.
    When I bought it the piston wasn't even in the bike. Now I'm a pretty decent car mechanic and I figured I could get this thing running. I bought the new piston kit from my local dealer had my recoil starter rebuilt because it wasn't retracting right. Still wouldn't start so I put some starting fluid in there and it still wont work the only thing I can think of if it isn't flooded which I guess is a possibilty is that this guy blew the rings drove it home and gouged the cylinder walls causing me to lose just enough compression to make it a pain, but it didn't look scratched when I looked.
    Aug 2007
    PA
    16
    but I didnt spray right into the cylinder I sprayed into the intake so that could be why.
