Results 1 to 8 of 8
Thread: 2003 Blaster cylinder question
    Jun 2007
    missouri
    50
    Im working on a friends 2003 yamaha blaster and have a couple questions if someone could please help.
    What is the stock bore of the cylinder? what is the torque on the cylider and head bolts? it looks to be nikisil plated???
    lastly, his piston melted on the exhaust side and he's got a good smug of aluminum running on the exhaust side of the cylinder, no pits or grooves that I can tell. I should be able to lightly sand that out and re-hone that correct?
    and if so, any links to other threads or tips on doing that would really help me out. thanks alot.
    Oct 2005
    saratoga, ny
    2,819
    if its nikisal plating use a diamond hone. but i dont remember blasters having nikisal on the cylinders. manual says stock bore is 66mm, cylinder nuts are 18ft.lbs. of torgue, head is 20.
    Jun 2007
    missouri
    50
    alright! thanks a million. Yeah im not sure if its nikisil or not. And I'm not sure if I'll attempt to hone it myself. thanks again.
    Jul 2006
    blasters are not nikisaled I would still rebore to the next size to eliminate any possible defects from the piston getting trashed.
    Jan 2004
    Palmetto,Florida
    2,300
    I AGREE !! ... anytime you have a Malfunction of oil,gas,jetting,heat and stuff in a 2-stroke ..... BORE IT and Disconect the oil injection and mix it like the BIG DAWGS do
    "07" DR650 Suzuki Dual Sport
    Oct 2005
    saratoga, ny
    2,819
    mixxing the gas/oil is definately the way to go. i wouldnt rely on that oil pump.
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    I lost two engine when I was younger to that damned oil injection. Never again. I agree, bore it and move on.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Sep 2005
    Lipetsk, Russia
    2,824
    You can use muriatic acid on the inside of the bore to get all the aluminum residue off the cylinder walls. Just don't spill it on the cylinder block itself or it'll melt LOL.
    I'm back in the USSR...
