Results 1 to 15 of 26
Thread: how do I put my top end back on?
    Pa.'s Highest City
    8,058
    never tried this.. and it was easy to get off though. Icannot get the rings to fit up into the cylinder.
    Any tips?
    N/A
    5,818
    works well with 2 people, one holding the pisting and one holding the ring to get it to compress....have your son help ya.
    kwbyfrmhell's Avatar
    kwbyfrmhell is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2007
    oklahoma city
    264
    ring compressor is only like 6 bucks at a lawnmower shop or autozone
    30 trikes of all shapes and sizes, Kawasakis, Yamahas, Hondas and a bunch of parts bikes
    springville, PA
    6,185
    I agree Chris, have little Chris hold the piston and you can mostly compress each ring with your finger and then use a screwdriver to push it the rest of the way.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Jul 2006
    western ny
    3,366
    i alway get my little brother over here to help me. he is 11 and has rebuilt 2 older sled engines. he knows how to but the cylinders on without breaking rings. i have him hold the cylinder and push it down lightly as a squeeze the rings in with my fingers or a regular but small screw driver as Liquid-Darkness said.
    GIT IT RAAAGGGGG !!!!
    Jan 2005
    RI
    2,530
    make sure you remember those little grooves in the piston ring spaces where the ends of the rings go...
    mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    May 2007
    oklahoma city
    264
    Hell I have used beer cans and hose clamps before
    N/A
    5,818
    take your time and just give it a rest for a day then, nothing worse then not giving up and screwing somthing up.
    Pa.'s Highest City
    8,058
    $200 for my local guy to do it.... THAT I cannot afford at this time.
    I tried pressing in on the side of the rings... but am starting to mess them up. (which is a bad thing)
    Not sure what to do at this point. I just wannna ride!!!
    N/A
    5,818
    if your messing the ring up get a new one, most times when ive done it if you get the part in where the ring is split you can push the rest in the your finger nail or a screw driver with a old rag over it....just use alot of motor oil
    May 2007
    oklahoma city
    264
    go get a ring compressor from a auto parts store (a smaller one)
    Jul 2006
    western ny
    3,366
    Quote Originally Posted by kwbyfrmhell View Post
    great idea indeed. cris if you cant get it on worse comes to worse you can send it up to me. ill do it for free just pay shipping both ways. i have no life till i start work again in a couple weeks. so i can get it done in less than a day and have it going back to ya.
    One way I use when I have no help is -
    Take the cylinder and flip it upside down, placed on a table. Leave one clip in the piston and pull out the pin and take it off the rod. Put the piston skirt side up into the cylinder and work the rings in with the fingers. Because the cylinder is flat on the bench, there is no flopping around or crooked BS. Just slip it in far enough to clear the rings and all you need is fingertips for that, I've never used a screwdriver in a hundred top ends. I usually insert the piston about 1/4" less than where the wristpin hole would be covered. Then I flip it over and slip it on then cases and slide in the wrist pin, pop in the clip and your done. Don't forget the base gasket and put a rag in the crank in case the clip goes flying....
    Maryland
    3,077
    Eh, the clips would be more trouble than the rings for chris. Chris just wait untill Josh or myself can come help you.
    Apr 2004
    Brigham, Québec, Canada
    1,528
    just a tought... may be the gap of the rings are incorrect???
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
